Scratch Build – Complete ⭐ The Iron Turnip--6-2019-complete. final pictures on page 29
Discussion in 'Project Logs' started by Cheapskate, 18 Jul 2014.
  1. Cheapskate
    13 May 2007
    :blush: Why, Thank you, Sir. It's good to see you around, by the way.:D
    Last we spoke, I was trying to get this awkward shaped part in the drill press.
    -Lets see...Nope! I'm hitting the slide frame.
    -Nope! Now I don't have room for a bit even.
    -I had to pull the cross-slide vise and use a normal one. :(
    -I drilled the PSU angle brackets- all over. I only shot one photo of the process.
    -And, BLAMMO! PSU/Mobo/reservoir mount, (mounted backwards, but it works.) This is still a bit wobbly since the back panel hasn't been made yet.
    I didn't think this bit out very well, though. There's no room for the cables. I guess I'll make some longer brackets? -We'll see after a few test fits.
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking awesome in that 2nd to last shot. :cooldude:
  3. Attila
    Attila still thinking....
    22 Feb 2008
    Adjustable brackets? Connect your wiring, slide PSU into position, nip up screws....... Maybe. :D
  4. Cheapskate
    13 May 2007
    @Waynio - Thanks.:D
    @Attila - I'm at the max distance for the black brackets, and the PSU said, "clang" when I stuffed it in the tank. Solution: More brackets!:lol: It will lower the psu 1/8" and get it to clear the weld lip in the tank bottom. There's a ton of unused space in that dome. I may be stuffing the pump in there.
    ...The fun bit is making a bulkhead to vent the PSU out the front somehow.
  5. storm-83
    storm-83 Minimodder
    7 Nov 2014
    if your bracket's bracket's bracket is causign trouble, you can always solve the problem by making more brackets... :thumb:
    this is looking like a very fun build!
  6. Nexxo
    23 Oct 2001
    Yo dawg, I heard you liked brackets, so I made brackets for your brackets so you can bracket your brackets while you bracket your brackets. :D
  7. Cheapskate
    13 May 2007
    :lol: I need a thesaurus for my CAD file naming. The whole thing is brackets. Perhaps I should start naming the parts like tropical storms? -Part "Bob", part "Betty," part... "Bindi."
  8. Nexxo
    23 Oct 2001
    Go wild: Part "Pineapple Express"; Part "Okey-Cokey Shake-Shake"...
  9. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Tell me about it,My current naming style ("fgfgfgfgfddfgdfg-FINAL" etc)leaves much to be desired.
  10. Nexxo
    23 Oct 2001
    Ada is known as "Metaversa 02-11b", which gives you an idea how many different versions I designed before I settled on her. :p
  11. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    With my current job revision control is critical and one thing I have learned is nothing is ever FINAL.
    Hmm, the directions for assembly could get interesting, fit Bob in Betty and screw until tight… *cough* err umm I'll stop there. Alternatively you could channel your inner Seuss… thingadoodle, jig-a-ma-wizer, wacket-a-booble.
    The brackets are looking good.
  12. Cheapskate
    13 May 2007
    :lol: Oh, God! Give them all pornographic names. If someone steals my rig, they'd spend the rest of their lives trying to get the files to work.
    -Alternately, I could find the culprit by searching for: ".nc doesn't play in movie player "
  13. onevoicewild
    onevoicewild What's a Dremel?
    20 Dec 2014
    Love your pic's, most peoples stuff you look at it and go hmmm. Your stuff, you look at it and then you look at it some more and the go WTF Hmmm. Wish I could do that lol
  14. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    haha, yeah Cheaps is def one-of-a-kind. :dremel:
  15. Cheapskate
    13 May 2007
    Thanks.:D
    @OneVoice - That's the response I get from women too. :( "hmmm, WTF?"
  16. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    have no idea whats going on but looking good cheaps!
  17. Cheapskate
    13 May 2007
    :D I'm seeing you a lot lately.
    -The test fit tells me there's more room for the PSU if I move it down a tiny bit, and my temp screws are too long.:I
    ...and the current bracketry sags a bit.
    -The PSU position requires a 90 degree power plug. Of course, none of the ones available go DOWN. I'm making my own from harvested PSU parts and spare cords.
    -The stock AMD backplate didn't trip my tra la la, so I made a new one.
    -I used a lot of degreaser to get the chips out of the tiny holes. This is already on the board, but I didn't snap a pic for some reason.
    -I mentioned on the modzoo I'm using window caulk for mounting the billet to the pallet. Environmentallyunfriendly, but effective. It doesn't flex like silicone does, and you don't have to wait as long for it to cure.
    ...mostly it's because I had a half-used tube lying around.:worried:
    -I haven't killed the grass in my yard yet, but I'm trying. I have bracket # 99,000 cleaned up, but I didn't snap a pic for some reason. I did that a lot last week.
    This dose of madness brought to you by the following:
  18. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Every update just confirms that you are nuts. And a genius. But mainly mad.
  19. Cheapskate
    13 May 2007
    So... I'm mad, but you don't want to offend me, but I'm mad.
  20. Nexxo
    23 Oct 2001
    When someone declares of your modding project: "This is madness!" you know you're doing it right.
