Scratch Build – Complete ⭐ The Iron Turnip--6-2019-complete. final pictures on page 29
Discussion in 'Project Logs' started by Cheapskate, 18 Jul 2014.
  1. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    This is a joy.
  2. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    cheaps
    i am so looking forward to seeing you sue that riser, ive been working planning a new project and it relies heavily on one of them
    i really cant wait to see how it works out for you
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    Good choice Cheapskate!
    They are the best extenders I've seen and tested. Even at 50cm it worked without a problem with a GTX970.
  4. disturbed13
    28 Nov 2008
    that is music to my ears!!!
  5. Teelzebub
    27 Nov 2009
    Looking good Cheaps
  6. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Im,quite frankly,disappointed at the lack of wayward machine tools or personal injuries in the last posts.
    Rectify this please.
  7. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    If Cheaps ever cleaned his house he'd never find any of his tools, though we would finally find out what happened to Hoffa...:worried:
  8. disturbed13
    28 Nov 2008
    first of all barry99705, i love the cheaps quote
    second... lol. what happened to Hoffa... lol. nice
    where is that damn like button when i want it!
    oh wait... its on a different site
  9. Nexxo
    23 Oct 2001
    Indeed, you can combine two for a 1m extension and it still works:
  10. disturbed13
    28 Nov 2008
    i was going to ask why not get the one by Lian Li...
    which was on amazon...
    but now i cant find it any where but mnpctech
  11. Cheapskate
    13 May 2007
    thanks, guys:D
    @B-Neg - don't say, "personal injury" and "rectify." in the same post, please!
    @Barry - I clean a LOT. Sometimes I think I'm the only person in the state that likes a clean toilet.:/ That said; It's a constant fight. Just this month we had the ducting and hot water heater replaced.
    @l3p & Nexxo - I'm just hoping it survives bending. They are a little stiff for SFF.
    @Disturbed - Lianli have 2 length choices, and shipping from China is cheaper than domestic shipping.
  12. Cheapskate
    13 May 2007
    Yeah, so, telling the world I was nearly ready to do a test run of the components was a flub. I royally jinxed myself with that comment.
    -Clearance issues arose that didn't exist before the GPU card was properly mounted. A big one is that the inlet on the CPU block is under the GPU block. -Measure six times, and still get it wrong. This solution should hold things over until I get a crazy idea about making a new CPU top plate.
    -See. It fits now, barely. The GPU is at a slight angle.
    -The GPU outlet had to be adjusted a lot. Here I'm cutting off about 1/8" off the radiator end of the pipe.
    -The other side was TOO SHORT by 1/8". There's no way I'm going to make a new pipe. The easiest way would be to shim the back outlet.
    -Fused over the original face. I figured I could jam an O-ring in the old seat if I didn't get it glued right.
    -Fixed, and it adds a bit more purple to the block. At this point I was ready to leak test.
    -The leak test was a success- It leaked. :lol: It seems that the pipes were tweaked enough to force gaps in the O-rings. I did some checking of the models and it turns out I didn't get the seat diameter right. :(
    So I had to make a new part from scratch. Remember how I made a billet big enough for 3 plugs in case my experimental pipe mount failed? -How freaking prophetic was that? :lol:
    -This time around, I thought it would be good to do the O-ring grooves during the main cutting session. This way, I didn't have to re-zero, and the grooves would be exact.
    Before I started, I melted some wax into the bottom of the holes so the MDF wouldn't soak up water and deform.
    -Clearance plane set to zero, cut depth set to zero, positioned in hole safely, GO!
    -Checklist at the ready. I was only called away like, four times or something, so the list was vital. Here I've finished the right hole cut, so I'm ready to zero the next depth.
    -Milled, cleaned, and a dark purple O-ring retainer added.
    -But, hey! Did you think that would be the end of the problems? I had to sand a steeply angled bevel on the pipes to get past the rings. The earlier Japanese porno comment was totally in my head as I violently forced the pipes in with all my weight behind them.
    -Several ruined O-rings later. I got both pipes through. You can see they are not exactly seated neatly in the grooves, but there's no way in hell water is going to get past them like this. I broke a pen I was using for leverage trying to turn the pump pipe.
    -The second leak test. This time I got to turn the pump on! :) Sometime today, I'll fit the PSU and get her running.
    -See! -No water pouring out. I did notice the pump is pretty loud. I traced it to the fact that the pipes from the res are resting on each other. When it's time to clean this up, I'll saw some metal off the pump outlet and fix that.
    -Still no leak.
    -and I'll leave you with this shot of everything together. Wish me luck.;)
    Thanks again to my sponsors:
  13. Nexxo
    23 Oct 2001
    Oh yeah... sweet, sweet shiny metal... :brrr:
  14. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Nice! I like the way this monkey works!
  15. Teelzebub
    27 Nov 2009
    Really nice work cheap
  16. Icelander
    Icelander Minimodder
    3 Mar 2015
    all crammed nicely together Cheaps..
  17. Zenator
    Zenator Minimodder
    12 May 2015
    Looking good:rock: and almost as much room to work in as my build :D
  18. Cheapskate
    13 May 2007
    Thanks, everyone.:D
    @Zen - Yeah, right...:lol:
  19. disturbed13
    28 Nov 2008
    maybe Cheaps needs to take a gander at this thread
    and maybe purchase one of these for any future builds/ projects
    might come in handy
  20. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    It seems the more carefully I have planned and laid out a loop great the severity and quantity of leaks I have. Loops I have tossed together with no plan rarely leak. I figure it must be part of Murphy's Laws.
    Possible, alternative solution to your clearance issue, could you have squashed the copper pipe? Never underestimate the value of a mallet when fine tuning.
