Scratch Build – Complete ⭐ The Iron Turnip--6-2019-complete. final pictures on page 29
Discussion in 'Project Logs' started by Cheapskate, 18 Jul 2014.
  1. Attila
    Attila still thinking....
    22 Feb 2008
    Awesome! It looks like the insides of a back-pack particle accelerator. :dremel:
    In that last shot, is it resting on cookies?:worried:
  2. Cheapskate
    13 May 2007
    Thanks, everyone.:D:D
    @Disturbed - Maybe cheaps needs to put ALL the O-rings in and not rely on the leak test did over a year ago on the reservoir. :p
    @Dr. Coin - I thought about it, but the spot that needs squashing is next to the O-ring seal to the pump.
    @Attila - Glad you like.:D I'm definitely not taking it on a plane. :lol: They are kinda macaroon-ish. Those are lead shot & leather paperweights from my Dad's cartography/drafting supplies. -really handy.
    Anyone else think this is absurd? Fancy computer clutter.:lol: Anyway, testing is good. No leaks, and she runs cool. I will say the pump sounds like a weed wacker at the moment. I noticed the inlet is resting against another pipe. I'l fix that later.
  3. Cheapskate
    13 May 2007
    My Purple Cap...
    -Mounting this chunk of fan clutch has troubled me for a while. It wouldn't clear the hump in the tank without hacking a bit out of it, and there's not enough metal to really tap screw holes into it. Getting a neat line on such a crazy shape to cut along was impossible too. My solution was to mill out a purple do-hickey.
    -Purple do-hickey gave me a place to seat screws, and it could be epoxied to the clutch. Here I'm using a bit to line up risers for fusing.
    -The plate's mounted up. There's some foam under the points to compensate for the curved surface.
    -A ton of spot filing later, and the clutch seats on top. Once I get this cleaned, I can glue the two together.
    -For padding: I found one of my Dad's old field manuals. Neat.:D
    -But holy crap, that's intimidating stuff in there. No wonder he always lost his patience trying to teach me math.:lol:
    Thanks again to my sponsors:
  4. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    there wouldnt happen to be an ISBN number on that book?!
    kinda looks interesting to me...
    but im
  5. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    And thats the field guide… I hate to think what the office/classroom version looks like. :week: Memories of university flooding back to me, ah stop it.
    On topic: The do-hickey looks good. The third picture reminded me of an astromech droid.
  6. EnviousMods
    EnviousMods Minimodder
    13 Apr 2015
    Man that purple cap is quite impressive. In a big fan of re-using materials for case/scratch builds. This build log has it all. Awesome sauce Cheaps.
  7. Cheapskate
    13 May 2007
    Thanks, guys.:D
    @Disturbed - Looks like a private publication for the Geophysical Society. -Oh God! I just noticed the page numbers are in hexadecimal. :lol:
    FINALLY! Now if I could get a female to say that...:worried:
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This IS Art.
    (nvidia cube spotting!)
  9. Cheapskate
    13 May 2007
    Compliment my doo-hickey some more.:D
    -Here we have a test cut for a leg, a valve spring from a lawnmower engine, and a brass cap from a sink drain assembly. The earlier complicated leg design was discarded because I want wobbly free-floating spring action. :D
    -It's a better fit than it looks. This part will help me figure out where to drill. I'm having to be strategic with the parts placement since the slide in module is a perfect fit. One wrong screw, and she won't go together.
    -More plumbing. I had to cut some more off the open end.
    -The top of the can needs ventilation for the PSU.
    -Lots of really loud cutting disc action later...
    -Don't ask me how I threaded that. After wiring GG and BLoo, This was a cakewalk. Wait 'till you see what I have to do to 'thread' those holes.
    -And there's a test fit for the sink faucet. BobaFett periscope?
  10. Cheapskate
    13 May 2007
    I noticed I spent an entire month Spring cleaning. I gotta post something for the kiddies.
    -Ah, spring, and it's warm enough to paint... in February. Here we have to wait for the yellow cloud of pine tree pollen to dissipate before painting.
    I've never spent a penny on blue tape, but I've amassed a considerable supply of it anyway.
    -The color scheme is purple, but I have a stack of RED fans given to me for GG's Custom PC write up. I don't have a red build even planned in the future.
    -If you need to swap out LEDs on any of these Phobiya fans... Drill the holes out. The fit is way too snug to get New LEDs in straight.
    -Annnnd... I don't seem to have any testing pics of the new UV lights. I guess you can use your imagination. :/
  11. InsolentGnome
    InsolentGnome Minimodder
    14 Apr 2015
    When life gives you red fans...make lemonade? *shrugs*
  12. Dr. Coin
    13 Sep 2013
    Never really been a fan of illuminated fans, and seeing the mess of wires under that fan just makes me glad I never bothered to use them.
  13. Vault-Tec
    30 Aug 2015
    I want my blue tape back :D
  14. Cheapskate
    13 May 2007
    @insolent - Keep working on that one.
    @Dr.Coin - There's the braided 4 wire cable and a power switch hanging off too. I gotta do some stuff to make all that fit in the case.
    @Vault-tec - Is a big silver ball OK?
  15. Convert
    Convert What's a Dremel?
    7 Apr 2011
    Your work is deceptive. Some might think it's ghetto at first but when you're done, it's amazingly well done. In comparison I feel like I have well finished parts to begin with and still can't get it to look as good as your work.
    You're a combination of Leonardo da Vinci and MacGyver.
  16. Cheapskate
    13 May 2007
    Thanks. :D
    It's all in the photos. You don't see the nasty scars in the metal if I don't photograph them. A lot of the salvaged bits are rough.
  17. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    For this there is filler.
    Long live the mighty Bondo.
  18. Cheapskate
    13 May 2007
    I'm not a big fan of U2...
    I don't want to use bondo on a bare metal setup. I thought about stripping the radiator too, but there's not enough brass. -However there's a few spots like a rivet hole in the fangrill that might get filled.
  19. B NEGATIVE
    8 Aug 2011
    I dont use Bondo at all,we dont get it in the UK...we get...
    or,if you really means business....
    if you want to retain the bare metal look then you need a metal based epoxy,Bostick do a good one thats not available for the UK market (dont ask where I got it.....) but you may have better luck in the US.
    I will PM a pic of it,if you cant get it in the US then I can mail you some?
  20. Cheapskate
    13 May 2007
    Pass. :D I'm still some using plexi to fill spaces and a whole can of silver paint.-Besides, I've seen shipping costs to the UK.
