Scratch Build – Complete ⭐ The Iron Turnip--6-2019-complete. final pictures on page 29
Discussion in 'Project Logs' started by Cheapskate, 18 Jul 2014.
  1. Cheapskate
    13 May 2007
    Thanks. :D The plan is to make the outside tank look less like a dong and more like a machine. ;)
    I'll try to get a partially assembled pic in the next update for you.
    ...well, I was planning that anyway.
  2. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    A dong, or a bong? :worried:
  3. amagriva
    amagriva Minimodder
    13 Jun 2009
    A dong, or a bong? Maybe a Kong!:hehe:
  4. Cheapskate
    13 May 2007
    That reminds me.. I never made space for sound dampening. (Yes, it makes all those sounds.)
  5. Cheapskate
    13 May 2007
    I took a week off to draw circles... many, many circles.
    -I said something about space for USB, right? First, I gotta get some decoration going.
    -Best use for those crappy steel T-slot toilet bolts yet.
    -Venting. This is what happens when the best way to cut the metal is with the edge of a cutting disc, but the hole is smaller than your discs. I have a grinding stone somewhere that's half the size it originally was. That's what I finished with.
    -Hack sawing only one side of this at a time.. Think about what an awkward Olympic event that must have been. Now imagine doing it in 98 degree heat. :(
    -For the curved bits on the above cut, I was filing back a ton of material. I thought, "This is killing me. I bet I have something that can do this faster. After some digging, I found a pack of rotary files that had never been opened in drill bit box #3. :lol:
    -I can't cut all the way through the tube, so I made a ding in the tank instead.
    -I still have some baseball bat left. Who wants to watch the mill party?
    -I got pretty aggressive with this cut. I found the vise was moving.
    -You know it's a good party when you have to shovel the swarf out of the way.
    -Here's what I plan to use that part for.
    -I spent a whole day buffing the cap of my turnip. -I said that. Yes, I did. The final polish shows off how dented up the tank is. I thought polishing the bit behind the purple plexi would look good.
    -Some of the polycarb scrap matches the curve of the tank, so I made a mounting block with it.
    -I finish up with a pic of a mess of tape and epoxy.
    -That's all for now. :D
  6. Cheapskate
    13 May 2007
    -This is the bottom connection for that tube. I may have over-engineered it.
    -Here's why it's done like that. It makes an internal countersink possible.
    -Here it is with the part that glues into the pipe. The electrical tape is to keep any glue from sticking.
    -I remember saying somewhere I would give a preview of what all this random madness would look like.
    -I bet you are all still confused though. I do that to people.
  7. Yukionno
    Yukionno What's a Dremel?
    9 Mar 2010
    Hmm, seeing the last 2 photos of your post, it kinda reminds me of a 60's hover/vacuum... it just needs a wire reinforced tube sticking out the end!
  8. storm-83
    storm-83 Minimodder
    7 Nov 2014
    either that, or it's an upgrade prop for the new fast & furious
    looking good either way
  9. Cheapskate
    13 May 2007
  10. Nexxo
    23 Oct 2001
    ...what, too soon?
    No, I can see where this is going. And I'm liking it.
  11. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Well those picture definite cast all your work in a new light. By which I mean, I can see how the parts now fit together. The case looks great.
  12. barry99705
    20 Apr 2008
    Hey, I see where this fits in!!
  13. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    I have no idea what I am looking at, but it looks nice and seems like you have some damn nice tools to work with - and no lack of either skills or creativity! :dremel:
    You are the man CheapSkate! Keep it up! :D :dremel: :thumb:
  14. Cheapskate
    13 May 2007
    Thanks, everyone. :D I had a feeling I was straining some imaginations.
    @Nexxo - It's been alive and on my desk, just without skin. -eww...
    @DrCoin - Honestly, This is the most I've had it together. Up til now I've only been attaching bits to check clearances.
    @Barry - :lol: No. I'm not sending my first born into space. It's a terrible place to raise a kid. -I mean, John Denver and JerryBerry are up there, right?
    -Can I get a, "That's what SHE said"? :lol:
  15. Badger
    Badger What's a Dremel?
    9 Jul 2016
    Awesome
  16. Cheapskate
    13 May 2007
    :lol: Bustin' forum cherries like a pimp!
  17. noobas4urus
    noobas4urus What's a Dremel?
    7 Oct 2014
    How long have you waited to say, "polish the head of your turnip"?
    That looks like a sweet pimped out desk companion if you ask me.
  18. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    cheaps, always 100% Original :rock:
  19. Cheapskate
    13 May 2007
    Thanks. :D
    @Noob - If you name the project right, you don't have to wait. Off-color jokes come to you.
    @Bill - Also 75% cheap, 34% crazy, and 3% math skills.
  20. flix
    flix Minimodder
    5 Aug 2009
    looking awesome, great work!
