The Kraken & Linux v7 client?
Discussion in 'bit-tech Folding Team' started by coolamasta, 28 Aug 2012.
  1. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Hi Guys, anyone know of any instructions of how to install the Kraken on the v7 client for Linux (Ubuntu 12.04) I am getting shockingly crap PPD at the moment so want to give this a go and see if it improves PPD...
    On the v6 client you just install the old Kraken into the fah folder and wrap the cores but as the v7 client lives somewhere else within the Linux file structure, Bin/Usr folder or something then im not sure how to install it, can't see much online after a quick Google so anyone know how to do it?
    Cheers for any help :thumb:
  2. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Not used it, but will be using it this weekend. :D
    Found this from the developer, but not sure about A5 cores after reading it...
  3. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    ive used it on the v6 client with great success but i couldnt find the files with the V7 client :(
    i wonder where the files are?
  4. Slowlemon
    Slowlemon What's a Dremel?
    17 Apr 2012
    Hi Chaps
    C:\Users\Username\AppData\Roaming\FAHClient
    This is the default install on Windows 7, I don`t have any machines running Linux. I should think if you know where to save the files then you can just follow the Guide on [H].
  5. One_Box
    One_Box Folder of the month April 2012
    11 Jul 2010
    Not sure why anyone running Linux on a multiprocessor machine would want to use V7 ?
    Presumably you would be wanting to maximise points and thus be hoping for bigadv or bigbeta which are A5 cores.
    Whatever PG say, in my experience 6.34 is more efficient than V7. Apart from anything else it does not have the overheads associated with FAHControl.
    For Linux the folders you need are hidden but in your home directory. Turn on "show hidden files" and look for .FAHclient The directory structure is slightly different to 6.34 but if you drill down you will eventually find the folder containing the cores.
  6. Slowlemon
    17 Apr 2012
    Hi Coolamasta
    FAH V7 in Ubuntu 12.04, the directory is /var/lib/fahclient. I have compiled thekraken but it will not wrap the a4 core. I get "problems occurred during wrapping, no wrapping performed (code 2)" Has anyone got this to work?
  7. Slowlemon
    17 Apr 2012
    Hi All
    I have got this sorted now. Follow Muskys guide at [H]ard forum but when you get to step 5 replace
    Code:
    cd ~/fah
    thekraken -i
    with
    Code:
    cd /var/lib/fahclient
    sudo thekraken -i
    You can check where the client is located from FAHControl. Click on the system info tab then scroll down and look at the entry next to CWD.
  8. Slowlemon
    17 Apr 2012
    Bigadv on V7
    To run bigadv projects on V7 in Linux you need to add two slot options to the SMP slot.
    Code:
    client-type = bigadv
    max-packet-size = big
    Note: bigadv will not work in Windows.
  9. kirk46
    9 Jun 2012
    Really :jawdrop: :(
  10. Slowlemon
    17 Apr 2012
    Windows
    Hi Kirk46
    Apparently the Windows client uses a 32bit core and the Linux client uses a 64bit core. Because bigadv can use more than 4GB of memory the work servers will not give bigadv to windows clients. If you are using Windows OS then run a virtual machine with Linux.
  11. kirk46
    9 Jun 2012
    cheers for that :)
