Scratch Build – In Progress The Making of " The White Shadow "
Discussion in 'Project Logs' started by G0oB, 27 Jul 2010.
  1. G0oB
    G0oB Fresh made Modder
    27 Jul 2010
    My First Mod ! The White Shadow !
    Wud up BT !! :), Im new here but still wanted to let you see my 1. project :dremel:,
    I have seen some amazing mods in here, at got inspired to try it out my self :)
    In the start i thought of making it a tree/alu mod, but decided to make it Alu and some Acryl plates
    here are some pics as it looks atm, still needs alot, and some stuff, i don't really have any drawings i can show you cause im working "out of my mind" i make the things as i comes :) but the hole idea is to make a big towers that looks a little stylish.
    Im waiting for the Watercooling, and some other components,
    Some of the stuff i got yesterday :)
    And some pics og the frame, at it looks like now :)
    Keep up for the updates as they will come running the following days :)
    / G0oB Out :clap:
  2. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Welcome to the forums fellow viking.
    Alu, acrylic and watercooling sounds good, but since the pics you posted doesn't work I can't say much else. Hope you get it fixed.
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Make it up as you go along, I already like :dremel:, but fix the pictures mate & welcome to the forums G0oB :D, subscribed :thumb:.
    Aha pictures fixed :D, good stuff.
  4. G0oB
    27 Jul 2010
    So i think this helped :)
  5. G0oB
    27 Jul 2010
    Waynio - Thanks dude :), always makes me happy to get a great welcome :D
  6. DeadP1xels
    30 Nov 2009
    almost looks the shape of those danger den towers :) with the quad rads in front
    Like the look of this im a bit of a improvisational modder aswell
    Good luck! and welcome to Bit-Tech i'll be watching
  7. G0oB
    27 Jul 2010
    Thanks :) havent seen those, :) but so far it just looks like a regular tower :)
  8. The_Gnu
    12 Sep 2005
    It's greate to see a case starting of from similar aluframe that I used. Love to see how you go on with fastening the rest of the parts since I myself are having some problem with the building up of material in the corners.
    btw. A tip is to try to get hold of a real camera instead of using your mobilephone since phonecams produce more blury pics that might not show all the details and not give justice to the build.
    good luck
  9. G0oB
    27 Jul 2010
    thanks man :),
    about the camera, yeah i know, but my camera was out of battery i will see if i can find some new ones somewhere for the next pics :)
  10. G0oB
    27 Jul 2010
    Update !
    The date is NOT right "! :D
    Acryl for the shelves before i made it "frosty"
    After it got "Cold" :D
    With the shelves, ( not attached yet )
    Just waiting for some stuff to get delivered . . :dremel:
  11. DeadP1xels
    30 Nov 2009
    care to share how you frosted the acrylic? :)
  12. G0oB
    27 Jul 2010
    This is my frosty secret :D
    and just do it in circles :)
  13. StEm
    StEm What's a Dremel?
    30 Nov 2009
    or you could buy a can of frost...
  14. G0oB
    27 Jul 2010
    why buy :)
  15. Remmes
    Remmes Be One With Your Mod
    24 May 2010
    woah.. size down those pics mate!!!
    nice start so far
  16. G0oB
    27 Jul 2010
    Remmes doesn't it rezise at you mate?
  17. Remmes
    24 May 2010
    they do resize from that 2000 x 1400 resolution to a smaller 1( auto bt resize) but i think you should resize it on the uploading site cause it still has a big lagg for me..
  18. G0oB
    27 Jul 2010
    Remmes, i will do that with the next pics i upload :), what size would be better?
  19. Remmes
    24 May 2010
    something like 1024 X 768 or 800 X 600
  20. G0oB
    27 Jul 2010
    Roger that mate :D
