Scratch Build – In Progress The Mineral Oil PC - 3/24/2011 - More leaks :(
Discussion in 'Project Logs' started by legoman666, 29 Jan 2009.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    congratulations on not finding a bridge to jump off and keeping a cool head when the leak happened dude! looks awesome how the oil flows through the case... you planning on some funky lighting in there?
  2. pulse
    pulse How do I overclock my modem?
    3 Jul 2009
    I'll start building my own oil PC soon and I was thinking of making it out of glass. But does aquarium silicone resist oil or will the oil eat it slowly away ?
  3. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    Thanks. I couldn't find a way to remove the audio altogether on Youtube, so I replaced it with the cheesy music.
    In other news, it has been about 9 hours since I filled it and no leaks. Hurray!
    My room is on the 2nd floor. My nearly empty 5 gallon container of oil was outside basement level. Lol, you should have seen me fly down the stair case.
    Thanks, I was thinking either red or white lighting but TBH, there really isn't room for it anywhere. I might be able to stick a few CCFLs on top of the radiators (below the tank). When viewed from the top, the bottom of the tank looks like a mirror so you might not even be able to see the lights, which would be a plus.
    I'm not sure. I did a lot of research on what types of plastic were safe for submersion in oil before buying some components. I made sure that my bulkhead fittings that go between the tank and lower compartment were mineral oil resistant. I bought the acrylic with that in mind as well. I also submerged two broken video cards with different types of capacitors for 3 months to make sure they didn't start falling apart. There was a lot of prep work.
    I'd be careful with glass too, it doesn't like to bend.
  4. Cheapskate
    13 May 2007
    Glass doesn't like to have holes cut in it either. Plexi is much more forgiving.
    Your power supply fan probably doesn't turn because of it's size combined with the weird way they undervolt them to make them quiet. (Don't you love how tech-non-savy I am. At least I didn't say 'thingamajig' this time.) You could probably get better results with a bunch of 40mm Deltas. It's not like they will make any noise.:D
    Dibs on your old radiator!!! If you don't want it, shoot me a PM.
  5. legoman666
    24 Aug 2003
    Cheesecake!
  6. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Looks good, congrats!
  7. legoman666
    24 Aug 2003
    Thanks!
    I recommend watching it in HD. SD kills the eddies, convection currents and swirlies.
  8. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    wow, looks simply awesome.
    How about some temp screenshots?
  9. Cheapskate
    13 May 2007
    Awesome. It has that 'freshly filled aquarium' look, only without the gravel and rocks.
  10. DESTroyed22
    DESTroyed22 PC User For Life
    25 Apr 2006
    I was wondering the same..... What temps are u getting on the cpu and vga cards?? a friend of mine and I are thinking of doing a mineral oil based pc also
  11. legoman666
    24 Aug 2003
    Heh, I like to stare at the swirling currents. Thanks!
    TBH, they're not very good. The lack of a decent TIM kind of kills the temps on the CPU.
    Both GPUs and CPU Idle. Note the ridiculous voltage on the CPU.
    Both GPUs loaded and CPU @ 100%.
    GPU1:
    Idle/Load: 46/52
    GPU2:
    Idle/Load: 52/59
    CPU:
    Idle/Load: 66/80
    The GPU temps are great though.
    Full load power usage. You should feel the heat coming out of the side of this thing.
  12. cogitoergosum
    cogitoergosum What's a Dremel?
    14 Jul 2004
  13. DESTroyed22
    25 Apr 2006
    man and u would think the temps would be lower.
  14. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    The G0 Q6600 happily runs at 3ghz with a x9 multiplier, 333fsb and ~1.3v core, how come you are running a 430fsb and such a high v-core dude?
    Only wondering unless you are trying to get it ridiculously hot? lol
    Awesome build by the way, been following it :thumb:
  15. DESTroyed22
    25 Apr 2006
    still an awesome build regardless, I love the case, tbh I doubt I could build a case so clean like that, im still a newbie lol, but I plan on giving it a try. do u know if distilled water will do the same thing?? or would it damage the actual components?
  16. coolamasta
    26 Apr 2009
    Water distilled or not will conduct electricity and it will go pop the second you turn it on, oil on the other hand does not conduct electricity which is why it works :thumb:
  17. legoman666
    24 Aug 2003
    Deionized water would work. .... for the 5 minutes it takes for it to pick up free ions from everything and become conductive. Tom's Hardware tried it: http://www.tomshardware.com/reviews/strip-fans,1203-3.html
    Thanks, good to hear my work can be of some use! 1/4" Acrylic is pretty strong stuff. 3/8" is damn near inflexible.
    Find me a mineral oil non-soluble TIM and I'd guess they'd be ~15-20C lower. My overclock is essentially the same, so maybe it's a non issue.
    Mine doesn't :( I temporarily have it at a lower multiplier (but not voltage) while I figure out the working temp of my new setup in the oil. With my old water setup, my Q6600 ran happily 24/7 @ 3.5ghz with 1.575V @ 430 /w 8x multiplier. Once I'm happy with the stability at this speed, I'll crank it back up.
    Thanks for all the comments guys!
  18. wagoo
    wagoo ドレメルってなに?
    7 Jan 2009
    Maybe there's a pocket of air stuck between the CPU and heatsink preventing the oil from entering.. you did turn it on after applying the oil as a TIM.. and watch it all leak out.. :) Maybe a remount with the same procedure?
    Vaseline as a thicker version of mineral oil might be worth a go.. but it may melt away at 80C and it'd be a pain in the arse if it decided to all solidify inside a radiator.
    Another idea would be something cut with channels on the CPU side mounted in between, giving both the TRUE and oil chance to cool the CPU. Could even have a 40mm fan whacking oil through these channels.
    It's great to see the main part of this project has come together nicely!
  19. woodshop
    woodshop UnSeenly
    14 Oct 2003
    What if you were to go more phase changeish with the CPU. Use some foam or something to seal the actual socket off from the oil and use a normal TIM?
  20. legoman666
    24 Aug 2003
    It's too late to do that for this hardware, but when I upgrade that's not a bad idea. :thumb:
    I don't think there's air between the two, the heatsink is on there pretty tight. Remounting it would make a mess :p Everything is covered in oil. I think you're right about the Vaseline dissolving into the oil, plus it's something I'd rather not risk. If my CPU is happy at 80C, then so am I ;)
    I'm not sure I understand what you mean about the thing stuck between the CPU and the heatsink. It sounds like you want to put a heatsink between the heatsink and the CPU? But why do that when the heatsink is already doing that?
