Scratch Build – In Progress The Mineral Oil PC - 3/24/2011 - More leaks :(
Discussion in 'Project Logs' started by legoman666, 29 Jan 2009.
  1. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    I question my own sanity.
    Putting everything into the case.
    I had to modify the bracket on the GTS250 on the end. It was a double height, now it's single height. :dremel:
    Fired up the system for the first time. It has no active cooling so I only let it run long enough to see that it worked.
    Excuse the poor cell phone pics :(
  2. oliverw92
    oliverw92 New Member
    15 May 2009
    AWesome! Want moar pics :D
  3. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    You have all that hardware..
    And yet you still have a CRT monitor handy ;)
  4. legoman666
    24 Aug 2003
    Thanks! With any luck, I'll have it all up and running today or tomorrow.
    Hell yeah! I think I have 3 15" CRTs and 1 15" CRT lying around. There's also a 19" LCD that I could have used, but I didn't feel like disconnecting it from the server it's attached to.
  5. blunc
    blunc Member
    25 Mar 2009
    I requested a sample of conformal coating (for evaluation), it came in a 3 ounce bottle (the sample was free), I basically used q-tip stems to drizzle the coating exactly where I needed it. You would only need to seal where the cap casing meets the PCB to keep mineral oil from attacking the seal on the bottom of the caps.
    If the mobo is the only place that had cap failure then it's probly a non-issue.
  6. legoman666
    24 Aug 2003
    Worked on the case a bit more tonight but not as much as I had wanted. I really wanted to finish it today, but my electronics design lab is sucking hardcore, so I didn't get home until lateish.
    I decided to dedicate a fan to circulate oil directly over the GPU heatsinks. Seeing as how there are three GPUs, there is a lot of heat that needs to be dissipated. So this is the mounting bracket I made for this purpose.
    I bolted it to the top plexiglass "lid".
    And here it is again with the tray down.
    And from the front.
    I made installed these little pieces of bent aluminum to hold the wires going into the tank in place. I was having problems with them not staying put and the zip ties getting snagged, so these should fix that.
    I also made a new hard drive mounting bracket. The only difference between this one and the old one is that the drives are now mounted top side up (when the lid is closed). Previously, with the drives upside down, the sata and power plugs were so close to case top that I had trouble getting the plugs in. This fixes the problem. :thumb:
    It's almost ready! There are a few things left to do: mount the SSD, clean the tank, clean the aluminum, and probably a few other things I'm forgetting at the moment.
    Till tomorrow...
  7. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    could you not have mounted that fan to promote convection between the cards?
  8. legoman666
    24 Aug 2003
    Like under the cards pointing up? No room :( The PCIe 6 pin power connectors are in the way.
  9. oliverw92
    15 May 2009
    Nice job mate :)
  10. Burnout21
    9 Sep 2005
    that's a bugger. due to the design of the cooler on the 5800 series, where one end is open for airflow from the fan.
    Could you not lower the fan a little lower to take advantage of that?
  11. legoman666
    24 Aug 2003
    Here's the cutout for the SSD mounting bracket.
    And here it is ready to go.
    In place. I used some screws that were already in place so that I wouldn't have to drill and tap any new holes.
    All ready to be oiled up!
    Then I carried it up to my room (10 minutes ago?). The next update should contain some yummy oil pics!
    I also took the chance to weigh the thing:
    Me + Case = 204.5lbs
    Me: 132.5lbs
    -> Case weight (empty): 72lbs (33kgs).
    + 6 gallons of mineral oil: 40lbs = 112lbs. Yikes
    Not exactly a feather.
  12. legoman666
    24 Aug 2003
    Houston, We have liftoff
    Filling... (~3 gallons)
    Filling... (~5 gallons)
    Full! (~7.5 gallons)
    Houston, we have liftoff!
    Fan spinning slowly (~300rpm is my guess, no RPM sensor though)
    Weeeeeee.
    Installing Windows 7 at the moment. Can't wait to OC this behemoth. 270W idle power draw.
  13. dark_avenger
    dark_avenger Well-Known Member
    9 Jul 2008
    Awesome to see it back up and running again :D
    Now get to OCing the CPU!
  14. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    i love this mod man:D be sure to make some videos of the fans spinning and stuff:p
  15. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    You need to take a video of this and put it up! Its to fantastic for pics! :D
  16. oliverw92
    15 May 2009
    Awesome! Temperatures?
  17. compmodder
    compmodder New Member
    23 Dec 2006
    Man, I am so happy to see you were successful. Congrats. +1 on gettin a video of somesort to show everything running.
  18. legoman666
    24 Aug 2003
    Will definitely try to get a video up soon. However, it sprung a leak late last night (right before I went to bed) so I drained it. The tank is not leaking, and I doubt one of the fittings is leaking, so it's probably one of my temperature sensors or the bulkhead fittings. I won't be able take a look at it until I get home from class later today.
    Neither is difficult to fix, but if it's the temp sensors, I'll need to take some time to redo the seals with epoxy (instead of silicone) which would require me to completely clean the polypropylene T's. If it's one of the bulkhead fittings, I'll just need to tighten the nut or re-seat the o-ring. However, if it's something else (I don't even know what) it'll take more time/effort to fix.
  19. Cheapskate
    13 May 2007
    This is Houston, Liftoff confirmed.:hehe:
    I fear it might be that bead you added at the bottom of the tank.
  20. legoman666
    24 Aug 2003
    Don't worry folks, I'm hard at work.
