Scratch Build – In Progress The Mineral Oil PC - 3/24/2011 - More leaks :(
Discussion in 'Project Logs' started by legoman666, 29 Jan 2009.
  1. Trenthan
    Trenthan What's a Dremel?
    3 Dec 2008
    Stupid question
    What industrial epoxy did u use to seal the caps on the m/b??? require 1 coat or a number for a good seal???
    Cheers Trent
    looks gud :)
  2. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
  3. legoman666
    24 Aug 2003
    Good news folk, I patched the leak in the top corner yesterday. I cleaned up the plexiglass with some paint thinner, let it dry, then applied silicone. I'm at uni now, but the plan is to refill the tank when I get home today
  4. legoman666
    24 Aug 2003
    EDITED.
  5. legoman666
    24 Aug 2003
    Back in business!
    Ph4ZeD likes this.
  6. The boy 4rm oz
    10 Apr 2008
    That is one sick display set up, I envy your Dell goodness.
  7. gnutonian
    gnutonian What's a Dremel?
    6 Jan 2009
    Nice work, and a jealousy-inducing climax with the last few pictures!
    You could put her naked next to the PC, desperate to have wild sex with anyone, and most of the followers of this topic would still go "Hold on hon, I'm just checking this out real quick... go watch TV or something." :p
  8. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Dude you are on sick ass mother ****er with that setup. Rep+
  9. legoman666
    24 Aug 2003
    Lol, thanks guys, made my morning.
    Also, another quick video:
    I'll try to get some decent photographs today when there is a lot of light in the room.
  10. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Wild, haha :D
  11. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Seeing as you have otherwise excellent taste in computer equipment, I was just wondering what the white keyboard in those pictures is?
    On a side note, is there anything that can live in oil?
    I was thinking (only for a second mind) that you could have a computer-heated aquarium, but fish don't live in oil >.>
  12. legoman666
    24 Aug 2003
    It's a Razer Pro Type. It's okay, the built in iPod dock is nice, but besides that it's nothing special.
    As for any creatures that can live in oil, I don't know but I doubt it :( I bet there's some bacteria or something that could though. Seeing as how they find bacteria living in the most extreme places, I'm sure there's some strain that could make do with oil. :thumb:
  13. Ph4ZeD
    22 Jul 2009
    I just did some reading about Mineral Oil on Wikipedia. Its interesting because I'd heard about people making PCs with vegetable oil as the coolant - but the huge downside of vegetable oil is that it absorbs water, so your non-conductive coolant will slowly become conductive. The Wiki article said that Mineral Oil doesn't absorb water easily so its ideal for computers. Also I presume it wasn't too expensive?
  14. Djayness
    Djayness phwupupupup
    7 May 2008
    I'm guessing he used parrafin oil, its pretty expensive in Australia, some $200 for 25 ltrs I believe.
  15. legoman666
    24 Aug 2003
    I used Shell Diala AX, which is mineral oil based and used in transformers and circuit breakers. I got it for free from work. It also smells awful.
  16. Djayness
    7 May 2008
    Well with 3 dell monitors youll have so much sensory overload you wont notice any smells :p
  17. Ph4ZeD
    22 Jul 2009
    Whats the cooling actually like mate? What are the temps like?
  18. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    This is a serious build mate good effort.
  19. legoman666
    24 Aug 2003
    They're actually pretty awful and I don't understand why. The CPU hits ~90C at load and the 5850's hit ~98C under load. Both of these are still under the thermal limit, but I think they should be lower. I plan on reconfiguring the fans to try and get lower temps.
    Thanks ;)
    Haha :D
  20. allogator
    allogator Oil Bath
    19 Apr 2010
    You've got a reservoir and pump on that thing so your temps definitely shouldn't be that high. Granted the other systems I've found didn't have SLI or Crossfire but with a decent pump system going they were generally getting 30-40 idle and 50-70 load. Maybe Crossfire just really does add that much more heat.
    I planned on doing this over the Summer and stumbled upon this post the other day during research and started reading from post one.
    One interesting thing to try (I planned on it!) was that adding a bubble stone into the mix helped drop temps. People doing it assumed it was because the bubbles helped transport heat out of the oil and into the surface air.
