SketchUp The MNPCTech Case Design Competition, part II: Scratch Build
Discussion in 'Modding' started by Xtrafresh, 14 Jan 2009.
This thread is made of pure:
  1. Win
    13.7%
  2. Win
    14.7%
  3. Win
    17.6%
  4. Epic design Win!
    51.0%
  5. Cheesecake
    55.9%
Multiple votes are allowed.
  1. Cheapskate
    13 May 2007
    :lol: A word of warning kiddies: SU is very cruel to imported organic meshes. For some odd reason, the surfaces move.:eyebrow:
    I need to re-do something now because my smooth frontpanel has a dent in one side.
    -Also, 20,000+ surfaces really freaks it out.
    No pics yet because it looks like a potato.
  2. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    ouch thats a lot =[
    im at 16,000 edges and 8,000 faces.
    and im no where near done!!
  3. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    show us what you are doing and maybe we can help you :)
  4. dan-ere-07
    29 Mar 2007
    ok your wish is my comand,
    heres where i am so far, its just the skin so theres a lot more to do.
    i have the outside designed (exept the front) but that will be the last thing i do.
    can get bigger pics if you wish.
  5. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    not sure if i'm entering yet :)
  6. skullen
    skullen Minimodder
    31 Oct 2007
    There are some very interesting designs so far,this comp will certainly bring out some great designs,good luck to all :thumb:
  7. Cheapskate
    13 May 2007
    @Bentleya - You D*mned well better enter something!!!!!
    You too, Skullen!
  8. talladega
    talladega I'm Squidward
    18 Aug 2007
    I have 166666 edges and 67326 faces. :)
  9. confusis
    confusis Kiwi-modder
    5 Jan 2006
    72202 edges
    31106 faces
    and im bored with the design :S
  10. stuartwood89
    20 Aug 2008
    I'm starting to have trouble fitting everything in.
    See, the SSD won't fit.
    I'm also a little worried that an IDE cable will have trouble in such a small space here.
    How long can an ATX PSU be anyway?
  11. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    Well i am hopefully going to be entering this time... I was considering remaking the tri-box design but have gone for something a little more adventurous...
    here is tri-box
  12. tominated
    tominated What's a Dremel?
    28 May 2008
    Why not have the ssd above or below the mobo like the optical drive?
  13. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    IDE cables can be folded over themselves both longways and cross-ways as seen about halfway down this page, so you should be able to move that out of the way somehow. Though, really, I'd go SATA if I were you (and had the money to do so).
    As for ATX PSU length - there's not technically a limit. The Zalman HP850 and HP1000 are about 210mm long, and the PP&C T12W is about 235mm. Obviously those are both extreme examples, but they're out there and cases are made to fit them.
    - Diosjenin -
  14. tominated
    28 May 2008
    anybody know how to countersink screw holes in SU? i googled it and it didn't come up with anything that i could follow.
  15. bradders2125
    bradders2125 What's a Dremel?
    14 Jul 2008
    @Tominated - Not sure if there are other ways to do it but the way i do it is once the hole is where it needs to be select the circle which makes up the countersunk side. select the resize tool then just drag it and it creates a counter sunk hole.
    Hope this makes sense, if not I can explain with pics and stuff.
    Bradders.
  16. tominated
    28 May 2008
    yep, make perfect sense. i should have known, it's so simple!
  17. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Still somewhat WIP. Might have to redo it though, it's already killing my rig (P4 3Ghz, 2GB RAM), I'm not even thinking about turning on shadows. Might have been a mistake to use 48 lines for all the the curves. In fact, it just crashed on me. :duh:
  18. skullen
    skullen Minimodder
    31 Oct 2007
    Got this so far :thumb:
    Got rid of pic,sorry if it was like a design in the other comp,dont want to upset anyone.:thumb:
  19. Cheapskate
    13 May 2007
    @Stuartwood - Where are you going to put the water cooling?:D I was thinking of doing a pico mod, but I wanted to build it into a trackball mouse.:hehe: I may just build a giant mouse.:D
    @Aterius Gmork - I like the double wall over the top! When the file gets too big, select/copy/new file/paste in place -is your friend. You can work on specific parts and then simply paste them into the main file when finished.
    @Skullen - I like!:D -but that looks suspiciously like the charred remains of a certain case... Late entry for the previous contest?
    I've gone through a whole bag of Doritos, and I only have a fanguard.:duh:
    It took 10 minutes to put it together, and 3 hours to fix corrupted intersections. I can't believe they have the testecalles to claim there's a 'pro' version of Sketchup.
  20. Aterius Gmork
    25 Sep 2007
    Thank's Cheaps. Actually I am using a lot of groups. It works out alright so far.
