Only picked up SU yesterday myself Joe but have you tried using the arc tool instead of the circle? also have a browse on you tube, there is loads of really good tuts on SU
Radiator-skis. The four 'eyes' are analog gages, but the lens part is also a fan control dial. (Thank Gozer I don't have to actually engineer that stuff. )
Wow!, there is some cool designs being presented in this thread. Keep em comin! Mnpctech Prize List Update! 2nd Place Prize Pool Exclusive, pre-production product from Mnpctech A new window cnc milled from 3/16" thick acrylic. It has beveled edges with countersunk fastener holes for #8 socket head screws and holds 4x 120mm fans
See now - THIS IS SCRATCHBUILD !!!!!!!!!!!!!!!!!!!!!! Change the color to brass looking, put a smokestack on the back and a steampunk-mobile is born. Well done, Cheaps john
Thanks, John. I'm going more for cast aluminum plates. @Bill - playing with acrylic again, I see. Is that spaced for radiators? I dropped something off at the post office on Friday... Edit: Thanks, Kylevdm. A TOTAL pain in the *ss. I had about 30 corrupt parts to fix on the radiator grill alone. -and don't look at the front blob too close.
Cool. Heres whats on the current menu for production All measure 13.5 wide x 15 tall Window Panel w/ 1x 120mm Window Panel w/ 2x 120mm Window Panel w/ 4x 120mm More configurations will be offered later.
thanks! it is only 700mm high yes it does but that is not the final pics and it hides some of the messed up polygons
I'm not going to show my design until, the last minute, but I'll happily show you my inspiration...: Its for an ITX board, with a small PSU and SSD, from American Black Whalnut. And here is a basic CAD drawing of the table, which I'm doing for my AS coursework, but without the central spans. Trust me. You'll like the outcome
wow some amazing designs, heres a bit more of mine. not final colours btw. plus all the little marks on the shell arnt there, its because im not zoomes in enough.
Still trying to grapple with sketchup! Might post mine soon! @ Mankz: I thought that it was sketchup only! Or can you import cobalt files? Dave
