Features The Modding Toolbox: A Guide to Heat Guns
Discussion in 'Article Discussion' started by bit-tech, 18 Jan 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    I purchased the Alphacool at christmas. Haven't bent my tube yet. A bit apprehensive because I know the hard tubing makes liquid cooling much more of a pain.
  3. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Nope. You strip wallpaper with steam; you strip paint with heat :duh:
    Also the mirrored image at the top of the article offends my OCD :p:
    Yes, but hardline tubing looks so much neater and cooler than traditional bendy tubing :rock:
  4. adidan
    25 Mar 2009
    Interesting to see it looks like the entry level B&D has had most use out of those Alex.
  5. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Gah yes you’re right, we did a lot of house remodelling recently and I mind blanked and wrote the wrong one, will slip the correct one in there haha.
    Will have to just live with the mirrored image though :p
    That’d be because it’s just ooooooold haha, no doubt was thoroughly abused before I ever picked it up. Only had the Bosch for about 8 months so it’s still pretty pristine.
  6. David
    7 Apr 2009
    I've always found them very cumbersome and weak compared to my soldering station's hot air tool. It's certainly better for close-in detailed work.
  7. Stanley Tweedle
    3 Apr 2013
    Agree. I have seen some pro mod builds still using bendy though but I agree the straight looks better. Bendy tubing is cloudy. I guess I have to get over my anxiety and fit the hard tube sometime.
  8. Cheapskate
    13 May 2007
    It probably should be mentioned that the insides of all of these are generally the same China-tastic junk, and the antique B&D is far sturdier than any model they have available now.
    -The guy that burns up cordless drills in a year.
  9. iggy
    iggy Minimodder
    24 Jun 2002
    You can also remove wallpaper with heat if you apply enough of it.
  10. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Not when I do bendy tubing.
    Yes, billet aluminium hose separators. I introduced those to PC modding. :cooldude:
  11. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
Tags: Add Tags
