Case Mod - In Progress The "Molten Armor" project completed.
Discussion in 'Project Logs' started by Dmitry, 3 Oct 2015.
  1. Dmitry
    Dmitry What's a Dremel?
    3 Sep 2015
    The project began with the purchase of an old broken radio Tank P-123M.
    In fact, it all started with the selection of the body. I wanted to have a non-standard housing in military style.
    The choice was stopped on the P-123M.
    After the purchase of a process of measuring, planning, disassembly.
  2. Dmitry
    3 Sep 2015
    All mechanisms and components have been removed. One unit went very well on the size of the body for the DVD drive.
    We used the DVD drive slot-loading.
  3. Dmitry
    3 Sep 2015
    Then I started cutting holes for audio and usb connector.
    It was prepared plate under the motherboard, hard drives, and a basket for the power supply.
    It cut a hole under the back plate and video connectors.
  4. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    someone robbed t-72? i'll watch, comrade!
  5. Dmitry
    3 Sep 2015
    The process of painting the body and blocks took a long time. I have used several versions of color solutions, before settling on the final monophonic decision.
    Coloring in camouflage color quality it is not passed. I washed all the paint stripper and re-painted in solid color used for painting tanks.
    It was carved by hand vents for the fan grille.
    All operations were performed manually using a drill and file.
    Laser cutting is not used. The budget was very limited.
  6. Dmitry
    3 Sep 2015
    Focusing on the color I started installation of buttons, key ignition, fans, switches and LEDs.
  7. Dmitry
    3 Sep 2015
    As soon as the components I had a trial assembly. It was necessary to test the functionality of components. First, I used the card GTX560Ti.
  8. Cheapskate
    13 May 2007
    Oh, Man! That is so awesome!:rock:
  9. Dmitry
    3 Sep 2015
    Final grade is:
    Components:
    motherboard: ASUS H81I-plus
    processor: intel i5- 4460
    cooler: Zalman CNPS 8900
    memory : 16 Gb Kingston 1600
    HDD: WD RED 1 Tb
    SSD: 120 Gb Kingston
    video card : Gigabyte GTX970 G1 Gaming
    Power Supply : Aerocool 700w
  10. ToddK
    ToddK What's a Dremel?
    3 May 2014
    Very cool. I like it!
  11. BLAMM0
    BLAMM0 What's a Dremel?
    28 Jul 2014
    Holly Batman! Impressive stuff ;)
  12. amagriva
    amagriva Minimodder
    13 Jun 2009
    I'm not a fan of military themed stuff but this look promising!
    Judging by the boxes of Sassicaia you know good wine so you have to be a good modder...
    Waiting eagerly updates!!:dremel:
  13. Cheapskate
    13 May 2007
    That thing is pure sex.:D I'd love to have a chunk of old tank hardware like that.
  14. Dmitry
    3 Sep 2015
    Thank you for your feedback! I am very pleased that you like.
  15. Dmitry
    3 Sep 2015
    You're right, I know about good wine. I work as an engineer at the restaurant "Buddha-bar". In his spare time enjoys modding.
  16. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    Kudos on creating something really original. It's totally awesome. I'm glad you went with he solid green for the final colour and put all of decals and stuff back on the front.
    Very neat work with the metal cutting too. Rad man!.
  17. Nexxo
    23 Oct 2001
    Tidy mod. Really good use of the case to fit the theme. I like.
  18. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Really nice!
  19. Dmitry
    3 Sep 2015
    Thank you for your positive feedback. You inspire me to new creativity!:хлопать в ладоши:
  20. Dmitry
    3 Sep 2015
