The Most Cost Effective High Wattage Power Supply – Thermaltake TR2 900W / 1000W
Discussion in 'Industry News' started by Guest-16, 12 Apr 2008.
  1. Guest-16
    Guest-16 Guest
    Thermaltake Technology today announced its newest line of power supply unit, TR2 900W and 1000W. These two models have the highest output wattage to date in Thermaltake’s most valuable and economical choice line - TR2 series. TR2 900W / 1000W is specially designed for high wattage and cost efficiency while providing built-in two 6pin and two 8pin PCI-E connectors for next generation multi-GPU graphic cards.
    Due to the rapid innovation in the graphics technology, power consumption of high-performance graphics cards is growing at an incredible pace. Today manufacturers are selling power supply units at 1000 or even higher watts. However, more power usually means higher price. To provide enthusiasts with a valuable choice for high wattage PSU, Thermaltake is pleased to present TR2 900W / 1000W as the excellent balance between cost and performance.
    TR2 900W / 1000W has a MTBF of over 100,000 hours and provides straight cable to deliver stable and continuous full-rated power. The use of Active Power Factor Correction ensures system builders a power factor of over 0.99 and reduces electrical waste for effective energy consumption. The PSU is equipped with four +12V rails to provide superior performance for PC system (combined loading of 75A).
    TR2 900W / 1000W will be available in Q2 2008. Moreover, in order to keep your systems running safely and smoothly, TR2 900W / 1000W were designed with over current, over voltage, and short-circuit protection to prevent damages to the systems. In addition, the PSU also has all the major safety / EMI approvals including UL, CUL, CSA, VDE, NENKO, CE, CB, FCC, and BSMI certification. Thermaltake is committed to provide users with the most valuable choices of high wattage PSUs that are the excellent balance between cost and performance. Check out the new Thermaltake TR2 900W/1000W Power Supply now: http://www.thermaltake.com/product/Power/TR2power/w0176/w0176.asp and http://www.thermaltake.com/product/Power/TR2power/w0175/w0175.asp
    About Thermaltake
    Thermaltake Incorporation, based in Taipei, Taiwan is the global leader Thermal Solution and Thermal Management for PC & Industrial Market. Its engineering staffs master in Airflow Analysis, Material Conductivity and Heat Dissipation Efficiency. Thermaltake offers a wide range of products and services, providing effective and cost-conscious cooling devices. The Company has more than 1,000 employees worldwide supporting customers from its headquarters in Taipei, Taiwan, as well as from offices in China, Europe and United States Continent.
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    80% isn't all that high.
    With a speed rising from around 1300RPM at 10% load, a noisy brute. :(
  3. Guest-16
    Guest-16 Guest
    It'll be "peak" 80% too unless it states a load value, but to do it at 115V is harder than 230V.
