Modding The name on the thing that opens the car door
Discussion in 'Modding' started by cgsimons_2000@yaho, 2 Mar 2004.
  1. cgsimons_2000@yaho
    cgsimons_2000@yaho What's a Dremel?
    12 Jan 2004
    The backdorr of a car is often held up by one or two things that pushes the door up..
    Whats this thing called?
    Where can I buy it?
  2. lamcdonald
    lamcdonald What's a Dremel?
    1 Mar 2004
    That would be a gas strut.
    Sorry, I'm not sure where you can get them.
  3. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Steal one off a car. :eeek: :hehe: :eyebrow: :worried: :nono: :lol: :naughty: check junk yards, body shops ect.
    WHOO HOOO Post #100 for me!!
  4. r3men4nt
    r3men4nt What's a Dremel?
    12 Nov 2003
    cgsimons_2000@yahoo.com: You almost might want to go for an electric actuator considering your mod and the fact that gas struts are usualy under quite amount of pressure due to the fact ath they have to lift the weight of a rear door of say a van.
  5. cderalow
    cderalow bondage master!
    23 Jan 2002
    try your local auto junk yard.... chances are they'll let you rip one out of a car for like $5
  6. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    i think i saw a case like that... cant remember the link tho. I'm pretty sure they have gas things like that for doors (horizontally mounted) that don't have so much pressure, so that your case door dosent smack you when u try to use a trunk strut LOL :duh:
  7. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    In Norway you can buy them at Biltema (and any car dealer for 10x the price, I'm sure)
  8. bo.v
    bo.v What's a Dremel?
    13 Nov 2003
    actually biltema has both expanding and contracting gas thingys ... I just mounted a contracting one in my case, works like a charm.
  9. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    i thought he meant though hydrolicys. you know it uses air compresed... lifts the back door up on its own... anyway like other people have said just rip one off i car..
  10. bo.v
    13 Nov 2003
    same thing, the contracting one is under $10 in biltema ... and makes a sound exactly like the one from a car.
  11. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    Mcmaster PG.1060
    Little more control over what pressures you have working for you than just ripping one out of a car.
  12. cgsimons_2000@yaho
    12 Jan 2004
    sensored :) Was drunk
  13. Fatboy
    Fatboy Bored
    8 Oct 2001
    HYDRaulics = liquid , with pumps and shizznit, as liquids are nigh on uncompressible.
    PNEUmatics = air, with electric/mechanical compressors and stuff.
    But these things are neither, when you close the boot you compress the air in the cylinders and when you unlatch it the presure forces the boot up.
