News The new future of water cooling? Water flows uphill without pump
Discussion in 'Article Discussion' started by WilHarris, 1 May 2006.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. Solidus
    Solidus Superhuman
    26 Dec 2005
    nice :)
  3. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Sounds interesting, although the CPU would need to be kicking some serious heat out if they were using water...
    - H.
  4. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    surely the cpu would have to be way above 100 celsius to do this? i dont know of any chips that can safely fun at that temp. do you?
    unless they use a different liquid that has a lower boiling point such as the various types of alchohol
  5. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    I posted a similar article in the Extreme Cooling forums in March. The kind denizens of Bit-Tech already pointed out several flaws. Of course, it seems like the idea is still in its infancy; who knows what these scientists will come up with in the near future?
    -monkey
  6. Comrade Penguin
    Comrade Penguin New Member
    3 Jul 2004
    Wouldn't have thought so. 100 degrees celsius is when water turns into a gas but you get water vapour which this uses from anything above zero. Higher the temprature the more water vapour (with the same amount of time and water in the system) hence the more this system would shift. If this wasn't the came how would get humidity? Also many of you are forgetting that water can change states not on due to heat but also due to pressure so in a pressurised system these tempratures would be much lower.
  7. Hans Voralberg
    Hans Voralberg New Member
    12 Mar 2005
    How far do we have to go to get from one droplet to about 300ml of liquid ?
  8. Shadowed_fury
    Shadowed_fury Active Member
    21 Nov 2003
    It'll be some time before this is performance cooling. ;)
    At the moment, and thats even after it works I can only seeing this being for uber-silence.
  9. Axly
    Axly slo-mo...dder
    7 Nov 2003
    I'm very interested in this particular statement...
    Currently laptops use external heatpipes attached to the chip to provide cooling, but these require additional power and generate heat themselves.
    additional power? generate heat? As far as I know the heatpipes in laptops are exactly that, heatpipes... A copper tube containing some sort of low dewpoint cooling media and possibly some added sintering or other capillary effect enhancer on the inner walls, no added power, no added heat.
    To be honest I have some problems seeing the revolution here.
  10. Adnuo
    Adnuo Banned
    28 Aug 2005
    The process works in a similarlyl to who water reacts when water droplets are dropped onto a steaming pan.
    Proofreading, please?
  11. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Well despitre the doubts whether it works like someone mentioned it's new, I hope they improve this discovery to make it viable for use in Computers of the future, sounds very interesting anyway...
  12. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    um...
    (emphasis added)
    Last time I checked, there are no pumps in heatpipes. All the laptops I've built (most of the Sager lineup, several Uniwills, and an ASUS) have heatpipes with no pumps.
    For that matter, what is an "external heatpipe"?
  13. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    It's a public holiday in the UK today and it seems editorial focus wasn't where it should've been. The story has now been edited so it actually makes some sense.
    To clarify, laptops use heatpipes, which have nothing to do with pumps, or watercooling for that matter. The original text quoted by Techno-Dann appears to refer to Thermo Electric Coolers (TECs) otherwise known as Peltier Coolers. These a) require lots of current, b) generate heat themselves and c) are often watercooled themselves, using a pump.
    Apologies for the confusion.
  14. Firehed
    15 Feb 2004
    The byproduct of shoddy research.
    Keep in mind that in a mild vacuum, water boils at room temperature. To demonstrate this, take a clear plastic syringe, fill it with water about halfway, cover the opening with your finger and pull the squeegee thing back further.
    Nonetheless, it's a very cool thing and hopefully will end up being more than some stupid research project.
  15. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    I wonder how much force/pressure something like this can operate under. Seems like applying this discovery to watercooling it wouldn't have enough pressure to move quickly enough through the blocks and radiators to be efficient. cool idea though!
  16. unrealhippie
    unrealhippie New Member
    24 Jul 2004
    Hmm, if you need something really hot to move it - Peltiers might just be the solution aswell as lowering temps for the processing unit itself.
  17. Adnuo
    Adnuo Banned
    28 Aug 2005
    Therefore completely defeating the point. If you're gonna use a peltier, use a peltier. The idea here is pumpless watercooling without the need for a reservoir, meaning it can be used in things like laptops, and it will eliminate the noisiest and most touchy component in a watercooling system.
    Nonetheless, it's nowhere near practical right now. Maybe in 10 years, but not right now. It's basically a heatpipe with water, meaning it cools better, as the general physics behind a heatpipe are that it transfers heat regardless of angle, direction, etc. etc.
  18. Lineage
    Lineage New Member
    19 Sep 2003
    i cannot see the video >.< damn.....
  19. I_Slider_I
    I_Slider_I New Member
    31 Oct 2005
    Seems like we're posting weird and useless facts about water... So did you know that pure water won't boil in the microwave, and will become super heated, so that when you take it out it will be well above 100 celcius. Then if you add an impurity say a teaspoon of sugar it will instantly and violently explode into boiling.
    --The more you know.... and didn't care.
  20. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    Sounds very much like capillary action
Tags: Add Tags
