Blogs The perfect netbook isn't a netbook at all
Discussion in 'Article Discussion' started by Sifter3000, 17 Jun 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    You need to get 10.1 Beta 1. Beta 2 doesn't work with iPlayer, something to do with the specific interlaced format their using or something.
  3. pimlicosound
    pimlicosound What's a Dremel?
    7 Sep 2007
    I used an MSI Wind netbook as my main PC for nearly 2 nears, before getting a Macbook Pro 13. I used it mainly for web browsing, Skype chatting and some light office work, and it was fine. With Windows 7 and an upgrade to 2GB RAM, the performance was OK on everything I wanted to do except HD Flash video. Neither the screen resolution nor overall size of the keyboard and trackpad were a problem. Conclusion: I can easily live with a netbook - except when my requirements change, hence the Macbook.
  4. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    I'm still using my Toshiba Portege R500. It's about 1.2kg, has a DVD writer, LED backlight etc., 12.1" screen. But it's hardly a netbook, more an executive ultraportable class machine.
  5. SteveU
    SteveU What's a Dremel?
    19 Jun 2009
    Forgive my ignorance but why do you need a Beta version at all, I thought the latest normal release of Flash was the proper 10.1?
  6. Meaty Pete
    Meaty Pete King of the Potato People
    8 Apr 2010
    Something I've been meaning to ask bit tech for good while now is that when windows 7 was released towards the end of last year I bought an ASUS eee netbook for under £320.
    HOWEVER the point is that it has 2GB of ram (yes 2!) and a single 250GB HDD. It has an 11.6" screen and Z something or other atom at 1.3 ghz but the ASUS BIOS has an auto overclock feature of upto 30% (which I have to admit is always on) overclocking it to 1.8 GHZ.
    HOW DID I GET THIS?!?!?! especially at the time, even now netbooks have only recently upped the usual 160GB HDD to 250GB
    What the jiggles?? Still can't get my head around it?? And I was reading custom PC and other PC review magazines ALL doing netbook reviews at the time and I was half expecting the newer specs to be creeping in but its now nearly 9 months later and still zip.
    Any thoughts anyone?
  7. Xir
    Xir Modder
    26 Apr 2006
    this Acer Aspire 3810tz is 460pound here (cheapest), which is about twice that of you standat "Netbook"
    It's a nice CULV though
  8. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    Had the original MSI Wind for a year, had to use it as my main computer for a while as my rig broke. It was...usable, just.
    I then got a bonus from work and had a look to see if netbooks had come on at all and in terms of performance and they really haven't. The only ones that appealed to me were the AMD based ones, much more power against the stagnant Atoms.
    The main feature I was interested in was the idea of a discrete graphics chipset. ION is crippled by the Atom while AMD/ATI setups were relatively powerful but sacrificed battery life.
    No longer needed the portability though and got a fully-fledged laptop and I'm now a very happy bunny. Laptop for going places where I have a power outlet, netbook for when I want the portability and a rig at home for my gaming.
  9. Tom @ CCL
    Tom @ CCL AKA: Yewen
    10 May 2010
    13" Macbook Pro is the best Netbook replacement in my opinion.
    9 hours real world battery life, lots of power when you need it and is very durable for use out and about.
  10. adam_bagpuss
    24 Apr 2009
    not really true considering you can pick up a netbook now between £200-300
    the laptop you have is £509 which is double the cost of a netbook and still £100-150 more than a full fat better performing laptop.
    even the cheaper version is £428 which is still £100-150 more expensive than your average netbook.
    considering a netbook cost around £250 and the CULV is £430 (basic version) thats a whooping 72% more.
  11. REMF
    REMF What's a Dremel?
    31 Mar 2009
    11.6" would be the limit of the size i would tolerate, anything bigger is just too bulky.
    looking forward to AMD's Fusion chips, should provide enough grunt for small form factor devices.
  12. jrr
    jrr What's a Dremel?
    18 Aug 2008
    I have:
    • unibody aluminum macbook 13" (the non-pro with a removable battery)
    • 10" vaio netbook (VPCW211AX)
    The mac is very comfortable to use, largely due to the super awesome trackpad.
    I selected the vaio for its screen resolution - 1366x768 over the meager 1024x600 of most netbooks. At ten inches, though, it's painful to use even with custom DPI settings and browser zoom. It's okay on a desk right in front of my face, but lap distance is too far! I still haven't become accustomed to the keyboard and the trackpad is just sad. Ubuntu support is pretty good, though =]
  13. lacuna
    lacuna Minimodder
    9 Aug 2004
    Ha, my 'netbook' is a 15" Toshiba satelite 2410 (vintage 2003). The battery doesn't actually last long enough to load windows so I guess it scores quite badly on that front but apart from that its great!
  14. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Ha, my 'netbook' is a 3.5" Nokia N900 - it comes with standard netbook performance too! Flash can run, but most of the time it's lousy, I can browse the web, I can edit documents, I can listen to music, but I get better battery life out of it.
    And in Singapore, the two cost similarly! Woo hoo!
    I still want a CULV, though. >.>
  15. Madness_3d
    26 Apr 2009
  16. Steve @ CCL
    Steve @ CCL CCL Tech. Support
    11 May 2010
    MSi GT 729.. Not really small.. but pwns..
  17. Tom @ CCL
    10 May 2010
    Not really a good battery life either Steve!
    High spec and long battery life do not go hand in hand.
  18. TheUn4seen
    TheUn4seen What's a Dremel?
    22 Oct 2009
    3810TZ looks nice, but it's still an Acer - which means it'll stop working and fall apart in six months. My friend owns one of the biggest computer shops in my city (strictly PC, not one of the electronics supermarkets for idiots) and just lately he completely stopped selling Acers - he said that when warranty return rates were (in some months) as big as 55% it was just too much work processing the returns compared to income from selling them. Acers are cheapest for a reason, if you want quality you need to spend some more money for a proper machine.
  19. Combatus
    16 Feb 2009
    Unfortunately I wrote the blog post a few weeks ago when it appears the Timeline was cheaper and I also managed to pick up my Timeline for about £320 after an eBay discount. I'm also comparing it to 11.6in netbooks such as the ASUS Eee PC 1101HA Seashell which I can't find for less than £300 so my argument did stand up I promise!
  20. Tom @ CCL
    10 May 2010
    Would disagree with the return rates youve quoted on that one. :)
Tags: Add Tags
