Photos The 'post your desktop' thread
Discussion in 'General' started by RTT, 26 Apr 2005.
  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
  2. Gareth Halfacree
    4 Dec 2007
    I've been imaging a bunch of old CD-ROMs over the last couple of days, and one had an installer for AT&T's WorldNet - which came with a 640x480 tiled backdrop bitmap.
    Quite fancied adding it to my collection, so...
    ...I recreated it as a 1920x1200 version to use as a wallpaper.
  3. Mr_Mistoffelees
    26 Aug 2014
    Now that is a proper geek's wallpaper!
  4. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    Persuaded work to give me another screen so had to rearrange the desk/setup....
  5. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    Basic and Simple
  6. Andersen
    Andersen Morally despicable and ethically objectionable
    25 Nov 2002
  7. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Now that I have my main display working properly again...!
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    What was the problem and how did you fix it? :)
  9. Byron C
    12 Apr 2002
    Use a dual-link DVI cable instead.
    I honestly thought that the DisplayPort connector was the only one that supports the full resolution until @jinq-sea put me straight on that! :grin:
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    You know, I recall you mentioning that the DVI was single-link and being a bit confused!
  11. Byron C
    12 Apr 2002
    I have no idea where I got that from, but I could swear I remember reading that the DVI ports have dual-link connectors but are only wired for single link. Clearly not!
  12. jinq-sea
    15 Oct 2012
    They're very Dual Link!
    bawjaws likes this.
  13. Gareth Halfacree
    4 Dec 2007
    I have discovered Window Maker, a modern (ish) interpretation of the classic NeXTSTEP desktop...
    ...and I *LOVE* it. Proper 90s computing, as it should be. Makes the Hipster Laptop feel like a classic, completely fits with the chunky styling and on-board trackball...
    Byron C likes this.
  14. Byron C
    12 Apr 2002
    Very nice, Mr H!
  15. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    What are you using to image the CDs with? I’ve a load of old backups from years ago and some of the drives won’t read certain folders. Disks have seen better days to be fair, was hoping there was something that could work some magic?
  16. Gareth Halfacree
    4 Dec 2007
    I started just doing basic dd, but - like you - found a few marginal discs that just wouldn't play ball. So I switched to dvdisaster:
    Not the fastest thing in the world, and the UI's a bit 90s, but it works a treat - you can see on that one a disk which was marginal managed to pull a clean image. It does resume, too, so if it can't read a disc the first time you can pull it out, give it a clean, and try again - it'll only try to rip the sectors that failed the first time around.
    's no good for CDDA, you'll need something else to pull the audio tracks - but works a treat for data discs.
    Unfortunately - or not, I dunno what OS you're using - it's only available for Linux and the BSDs these days. If you're on Windows, there's an older version here - it's only a few sub-versions older than the one I'm using on Linux, so it should work fine.
    Arboreal and DeanSUNIAIU like this.
  17. Mr_Mistoffelees
    26 Aug 2014
    For audio I use Exact Audio Copy. It does a fine job, has powerful error correction and recovers data WMP misses altogether.
    Gareth Halfacree likes this.
  18. Gareth Halfacree
    4 Dec 2007
    I was using something at the terminal to create BIN/CUE pairs from mixed-format discs... and I've completely forgotten what it was and how to use it. Whoops!
    EDIT:
    Found it! It'd long since vanished from my bash history - I really need to carry on with the job, I've still a load of discs to go through - but the results of my "how the hell do I do this in Linux" searches were still in Firefox:
    Code:
    cdrdao read-cd --datafile image.bin --driver generic-mmc:0x20000 --device /dev/cdrom --read-raw image.toc
    toc2cue image.toc image.cue
    First line rips to a BIN and a TOC, second converts the TOC to a CUE.
    Mr_Mistoffelees likes this.
  19. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    Thank you, I’m good with *nix so I’ll definitely be trying that out. Thank you
  20. Gareth Halfacree
    4 Dec 2007
    Little bit more tweaking...
    adidan, Almightyrastus and Byron C like this.
