Scratch Build – In Progress The POWER CELL - ZenModz "COMPLETED"
Discussion in 'Project Logs' started by Zenator, 11 Oct 2015.
  1. Zenator
    Zenator Minimodder
    12 May 2015
    Small update!
    Thanks for stopping by.
  2. Cown
    Cown Minimodder
    25 Feb 2012
    Holy moly :jawdrop:
    Superb design, that will turn heads for sure!
  3. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks Cown, I hope so. :D
  4. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again,
    Progress has been slow but I have fitted the rads a fans, GPU, Mobo, PSU, and are now there to stay. I have also added the same shapes to the inside of the pillars that can be seen on the outside but the ones on the inside will glow white when lit with black light. and the white of the pillars wont.
    Have to get more soft tube as well don't have enough to the bottom of the loop. Going to start the inside loop over the next week. And I'm still painting the case as I go.
    In this photo on the right you will see the clear cover that will be going over the 3x3 loops that will be running up and down the outside of the case. And the ASUS logo that has been sprayed on all 3 sides.
    Here is a front shot of the clear cover.
    Here you can see the tiles that will glow white under black light this is done on the inside of all 3 pillars and the bottom.
    GPU is now all done PCI-e extender or riser is now fitted as well.
    Here I have made a cover to hide the PCI-e extender.
    I run the HDMI and Display feed out the back of the case, And can still removed, but for now will be staying for testing later.
    Not a lot of work space here and the nest inside will need some work.
    SSD is now fitted as well.
    I will keep the updates coming as the painting starts to change the look. Most of the painting I have left will be done with the airbrush. and paintbrush.
    Once again that's all for now, Thanks again for stopping by.
    Cheers, Ken.
  5. Cheapskate
    13 May 2007
    That splash of "Rebel scum" red. :D
  6. Zenator
    Zenator Minimodder
    12 May 2015
    The funnest thing is you called this build from the start, I wouldn't want to disappoint you now. :D
  7. Arboreal
    21 Jan 2011
    That detailing and shading is making it look really good. Really impressed with where you've gone with it.
    /airbrush envy
  8. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks Arboreal.:thumb::D
  9. Zenator
    Zenator Minimodder
    12 May 2015
    Last update till completed.
  10. Zenator
    Zenator Minimodder
    12 May 2015
    Hi All, One last small update till completed.
    Thanks again for stopping by, More Soon.
  11. Zenator
    Zenator Minimodder
    12 May 2015
    Some better pic's this time. The camera on my phone makes things look to have too much colour. The pic's below are true to the look of the case.
    Hope you all like.
    Thanks again for stopping by. will post finale photos as soon as I can.
    Cheers Ken.
  12. Cheapskate
    13 May 2007
    :clap: Awesome!
  13. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks Cheapskate. :D
  14. storm-83
    storm-83 Minimodder
    7 Nov 2014
    insane! :thumb:
  15. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks storm-83 :D
  16. Johnny71
    Johnny71 What's a Dremel?
    6 Jun 2012
    AWESUUUUUM! :D
  17. noobas4urus
    noobas4urus What's a Dremel?
    7 Oct 2014
    Soooooooo good! I'd love to have that powering my house!
  18. Zenator
    Zenator Minimodder
    12 May 2015
    Cheers, Guys. Will start with the stats testing soon as well. But it does play fallout 4 on Ultra-high at 1920x1080 and that's what the game sets it's self too. Witch is more then the fallout 4 case witch runs on medium settings. The GPU is doing is job nicely.
    Cheers, Ken.
  19. Icelander
    Icelander Minimodder
    3 Mar 2015
    this looks awesome Zen
  20. Zenator
    Zenator Minimodder
    12 May 2015
    Cheers, Icelander :)
