ARE YOU READY TO RUMBLE?!?! ...er....mod I am in the planning phase of modding my case...a Codegen 9000 mini-serwer (don't laugh...I know...I know...) Here's what I'm planning to do: Add a laser engraved side window add small window on right side panel add 2 Cooler Master AURORA green CCFL's add 1 red CM aurora CCFL add Cooler Master round cables Replace both rear fans and PSU fan with Cooler Master RED LED fans clear plexi PSU cover Cooler Master AEROGATE 2 (all three optical devices will be behind door, incl. floppy[CM AERO7 Lite fanbus will take the flopps place]) 120mm Tt red LED intake fan on top 7,8" LCD on top (I hope.....it all depends if I wire her up) The whole case will be painted dark green. Anything else I should consider? Cheers, Mike
Depending on your country (if UK try ebuyer) to get a cheeper CCFL nice case otherwise with lots of potential!! Why do you need a floppy, cos you dont need one really?
I'll have to think about it. I'm not sure about red and green, but you may pull it off. The screen is a good idea though. If you're dumping the perforated 5.25" bay blanking plates, can I have two please?
Im running a mix of red and green lighting now...the challeng is not to let the light mix....if the colours mix u just get white light....so u gotta spread um abit to get decent effect...i got a red and green cathode and use some well placed cardboard and metal sheeting to angle the lighting so it dosnt mix.
Hehe...sure, I have two that I won't need Maybe you're right kill_me_quick, I barely ever use the floppy, ZIP disks all the way! Just thought about adding some red leds to the outside bottom of the case Cheers, Mike
