Case Mod - In Progress "The Purple Dragon Project" | April 29th 2007 | COMPLETED! Pics and details on Page 2
Discussion in 'Project Logs' started by Hasle, 28 Apr 2007.
  1. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Before I start my endless blabble and picture posting, do note that this mod is already finished - it has been for quite a while now. Though, I have a new casemod in the making, and figured it would be a good idea to post my old (and first) one here, to give you an idea of what to expect. I have more than plenty of pictures from the process, and will be serving you these in a suitably paced manor, to make it feel like a "real" work log.
    Anyhoot, onwards.
    This is my first ever casemod. It has been a few years in production, being modded in two stints. The first version wasn't quite as I wanted it, so I expanded and developed the concept, with my main goal being the "Casemod of the Year 2005" contest on Tweakup.dk. Sadly, I missed the deadline, but I ended up with something I was quite proud of.
    Let's start at the beginning, stint one. Do note that a few of the ideas on the following pages were scrapped in the end product, I'll notify you when I commence the second stint, the one that built up to what it is today. First up is:
    The Case
    The cellphone in the first picture might indicate how old these pictures really are, hehe. It's an Ericsson, from the time before they merged with Sony. I don't even remember what it's called. An A26...something.
    Now, when I picked this, it was mainly for the flashy color. At this time I wasn't planning anything specific, just wanted a new case to replace the crappy, cheap, plastic littered, 0.7 cm zink built heap of a case I was currently in possession of. A sturdy Chieftec case seemed like a good replacement.
    The Modding
    It would be months before I laid hands on the case. What set me off was a mod I saw on Metku. Someone had squeezed four 80mm fans into the front of his (smaller) Antec case. The innards are pretty much identical to that of my Chieftec, so I gave it a whirl. Before I show you how that turned out, here's a few pictures of what I did to the case before that:
    Installed a CoolerMaster Musketeer and a small Papst 40mm fan.
    The goodies for my PSU mod. A purple acrylic cover, black cable sleeving from Vantec, a very silent CoolInk 80mm fan, a Y-cable and some fan screws, and a fan grill I ended up never using.
    I drilled all the venting holes myself. Think there was about 90 in total. Took ages.
    I think that's enough info and pictures for one post. I'll post more, mainly of the 4x80mm fan mod in a minute.
    All comments are welcome.
  2. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    All masked up and ready for some hacksaw action.
    The last picture you can see how I cut out the part in the front where the four 80mm fans will be mounted. Sadly I don't have any pics of the mounting plate being cut, or the fans being mounted to it, but here's a few pics of it being painted, and after it was mounted to the case:
    The next step was to mount a fan controller, in this case a a simple panel with switches and LEDs, from NoiseIsolator.
    And then there's another gap in my stash of pictures. I'll be removing the front grill of the case, and installing a window in the door, the aftermath pics will follow in the next post.
  3. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    nice color choice :D i'll watch this one
  4. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Before I show you the front window, some assembly pics:
    CoolerMaster CoolDrive 3, two Revoltec 60cm 3-pin extension cables, two blue cathodes and a Thermaltake TrueLight RAM cooler with blue animated light.
    And here all the above products have been installed. I also sleeved various cables.
    Here you can see the front with the removed grill and new window, which still has the protective film on it.
    I cut some small, round pieces of acryllic, painted them black, and mounted them to the center of the fans.
    And yes, I know the fans are a bit off center, but the motherboard tray made it impossible to move them any further to the right.
    Flick the switch and push the button to power on the PC. Found it in a car accessories shop.
    Fitted some black mesh over the fans.
    And that's how the case stood for a few months. End of the first stint. Now the more creative modding can commence. I'll update in a little while.
    Tata.
  5. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    very nice just wondering whats it got to do with dragons.
  6. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Thanks mate.
    The case is called the Chieftec Dragon. And it's purple. There's your connection. :p
  7. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    im guessing the name has something to do with the fact that its a purple chieftec dragon case! lol
    good mod well done
    damn too late
  8. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    The Modding - Stint Two
    This is where I decide to enhance the case a bit up to the contest I mentioned earlier. It was also time for an upgrade.
    Parts!
    CPU: AMD A64 3200+ (2200 MHz) (Socket 754)
    Motherboard: Soltek SL-K8AN-RL
    PSU: NorthQ 4001-BL 400W (17 dBa)
    CPU Cooler: ThermalTake Pipe 101
    Fan: ThermalTake Silver UV, 92mm UFO Fan
    Also in the picture is four black thumbscrews and a Hauppauge TV-tuner card.
    The heat pipe cooler in all its glory, with the UFO fan mounted. I admit, the fan isn't that pretty, but that changed.
    Only decent motherboard I could find that fit the theme.
    And here's the cooler and CPU installed.
    More parts!
    Goodies arrived from www.caseking.de:
    Stuffed box!
    Let's lay out and name the various parts.
    • 1x 120mm Aerocool Turbine 1000
    • 6x 80mm Aerocool Silver Blade II
    • 1x AC Ryan Alumino Fan Filter 120mm, black
    • 6x AC Ryan Alumino Fan Filter 80mm, black
    • 1x Lian Li LCD Thermometer & Fan Controller TR-3
    • 1x AC Ryan MORF PSU Modding Kit, black
    • 1x Sharkoon Roundcable U133, 45cm
    • 1x *Floppy cable, round. black
    • 1x Sunbeam LED Screws, 4-pack, blue
    • 4x Sharkoon Rubber Bolts, 4-pack
    • 4x ThermalTake Ducting Mod
    In the next post you'll get to see how some of these items were used.
  9. Archtronics
    27 Jun 2006
    oh of course shame on me.
  10. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    I should mention that at this time I've also purchased a few sheets of 3mm thick black tinted acrylic, and a handful of M4 hex bolts.
    Cut a hole for the new top window.
    Top window cut. The big hole is for the 120mm Aerocool fan.
    Still need to pretty up the holes, hehe.
    Test fitted the top window with a few of the buttons.
    Now, I wasn't quite satisfied with the clear 80mm fans I used in the first go, so I replaced them with the AeroCool Silver Line II fans you saw above, and mounted them with the rubber "bolts".
    Snug fit. It was hell to get the last fan on.
    Test fitted to the case. You can also see a bit of the paint I'll be using in the background - flat black.
    Mounted one of the ThermalTake ducts to see how it would look.
    More later.
  11. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Didnt like the color that much, but looks promising! ;)
  12. exitus
    exitus What's a Dremel?
    25 Apr 2007
    they say that purple is the colour of unsatisfied women :D
    you're not a woman, are you?
    btw: i like what you're doing there, finally someone who uses a colour that not everybody has
  13. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Hey I've been looking, at this case on tweakup. You've been very inspiring.
    Nice to see how you builded it, I'll follow this one :)
  14. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Who are "they"? :eek:
    But no, I'm very much male. Let's hope that unsatisfied women will feel drawn to the case and its owner, eh? :p
    @jegerjon: Ah, cool. Glad you like it. :)
  15. ComputerKing
    8 Sep 2006
    holy *******************
    man this is over control , WOWO
    keeeep it , I will follow this too
    good luck
  16. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    So, now for more cutting, sanding and painting.
    Flat black, yummy. Got a few more coats after this. In this picture you can also see the hole I cut for the two rear fans, which will be the same AeroCool ones used in the front.
    The upper and lower part of the front window and the mounting plate for the rear fans got a shot of paint, too.
    In the top window I mounted a key switch and a Bulgin vandal button. It's a simple setup that requires you to turn the key before you're able to boot up the PC, using either the Bulgin button, or the one behind the front door, that's what I'm soldering in the picture above.
    Now I could start assembling the case again.
    The ducts are supposed to direct some of the airflow towards the southbridge on the motherboard, but they're mostly just there for looks.
    After this I have very few assembly or work pictures, as I had a deadline. In the next post you'll see the finished product, so I'm saving that for tomorrow.
    -Az
  17. Dj Ovin
    7 Nov 2005
    Looking good then, cant wait to see the final pics :)
  18. Archtronics
    27 Jun 2006
    I like the ducts to they light up.
  19. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I don't really like the purple paint(I like black), but it's still a pretty good mod
  20. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    I'm a big fan of black, too. That's why pretty much all the items and details I've added to the case are indeed black. I was afraid that repainting the whole case black, would have the said black details drown out and become less noticeable. Then there's the whole fact of the color not being used very often, and I found that to be a quality of its own. Maybe you'll like it better when you see it all assembled and lit up. :)
    Thanks for the comments peeps.
