Scratch Build – In Progress The Razor's Edge
Discussion in 'Project Logs' started by Iraklis Gkolios, 2 Dec 2014.
  1. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    learning how to do something is never a waste
    - unless you keep making the same mistake every time
  2. Vognen
    Vognen Minimodder
    2 Oct 2013
    Aw man this case is just getting more and more epic! I can't to see it once you start slabbing in some hardware! :rock:
  3. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Plexi turned out great! LOVE the shape of it! Can't wait to see it all prettied up! :rock:
  4. Iraklis Gkolios
    Iraklis Gkolios Minimodder
    21 Aug 2013
    I am glad that you like the case and you follow the project almost from the beggining.
    Now back to work.
    I drilled the hole for the power button on the front of the case.
    Now one strong candidate for the color is this one
    Cheers
    Iraklis
  5. Iraklis Gkolios
    21 Aug 2013
    Hello everyone.
    Today i had some time to work with the power switch. As you can see below i have used a different kind of sleeve is this build. You can find it on gardening supplies stores. Its a gardening tube for watering the plants with drops. Its very cheap and durable and it also gives a very good result.
    If you want to help me you can like or comment my thread on the coolermaster modding contest.
    http://community.coolermaster.com/index.php/topic/15569-razors-edge/
    Cheers
    Iraklis
  6. Cheapskate
    13 May 2007
    :thumb: Black PVC hose is great. I use the small 1/4" stuff all the time instead of sleeve. It's tricky to get more than 3 wires through it, though.
  7. Iraklis Gkolios
    21 Aug 2013
    I went for some shopping today.
    I bough some adhesive skid protector so i can move the base easily and avoid scratches.
    I also looking for these switches (the ones that disengage the batter from the laptop). If anyone knows how they called id like to share that information.
    http://community.coolermaster.com/in...9-razors-edge/
    Cheers
    Iraklis
  8. Cheapskate
    13 May 2007
    You may have to make those latches custom. All they are is a spring-loaded hook.
  9. Iraklis Gkolios
    21 Aug 2013
    That was what i am afraid also...
    So... can anyone guess whats the part i am working on is going to be ?
    Cheers
    Iraklis
  10. Iraklis Gkolios
    21 Aug 2013
    Today i found some time to work with the 2nd LED bracket. Now its time to start working with the actual leds and acrylic.
  11. Iraklis Gkolios
    21 Aug 2013
  12. Supercluster
    Supercluster I dream in G-code
    16 Feb 2015
  13. Cheapskate
    13 May 2007
    They came out REALLY good. :thumb:
  14. Iraklis Gkolios
    21 Aug 2013
    I fixed the link, you can try now http://community.coolermaster.com/index.php/topic/15569-razors-edge/
    I am glad that it came out nice with the first try, because i had mesh for only two side panels, so if i messed up ill had to wait for around 20 days or more
    Cheers
    Iraklis
  15. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    You are doing a great job !!
    That mesh is amazing :rock:
  16. Iraklis Gkolios
    21 Aug 2013
    I am glad you like it :)
    Are we ready for some LED action ??
    This is an old RGBW led tape i found, its super bright and it works like a charm with my RGB controller.
    If you want to help me you can like or comment my thread on the coolermaster modding contest. http://community.coolermaster.com/index.php/topic/15569-razors-edge/
    Cheers
    ​Iraklis
  17. Iraklis Gkolios
    21 Aug 2013
    Hello everyone.
    I just came back from my vacations and found some time to work with the led plexi, its still incomplete but you now you can have an idea how its going to look.
    If you want to help me you can like or comment my thread on the coolermaster modding contest. http://community.coolermaster.com/in...9-razors-edge/
    Cheers
    Iraklis
  18. Iraklis Gkolios
    21 Aug 2013
    Today i finished one of the led panel. Unfortunately i messed up something and the led controller doesnt work. Ill have to sort it out later, but you can get an idea how its going to look.
    Cheers
    Iraklis
  19. Iraklis Gkolios
    21 Aug 2013
    Since i wansnt able to sort the things out with the LED controller, i order a new one and the mean time i decided to work with something else. I decided to change the brown anti vibration pads with the white ones. Tomorrow ill sleeve the cables and work with some custom stickers.
    Cheers
    ​Iraklis
  20. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I quite like this build so far, great work! :dremel:
