Case Mod - In Progress The Riddler [w/c & Airbrushed H440] - Completed
Discussion in 'Project Logs' started by _TechPuppet_, 19 Jul 2015.
  1. _TechPuppet_
    _TechPuppet_ What's a Dremel?
    1 Feb 2015
    Hey everyone, welcome to my build log for my "Riddler" build. I have a H440 Special Edition Green Case and I went with the "Riddler" theme from Batman.
    Decked out with Green and Purple, this build has a beautiful airbrushed mural on the case to go with the added touches of vinyl which helped the build really pop.
    I used vinyl to fill in sections throughout the build to add color and character, including the EK badges and the yellow designs on my MSI Mpower board and much more.
    I included custom Purple anodized screws to help balance the Purple and green and to bring a little dazzle to the build. Leave your comments and post your opinions.
    Thanks for checking out my build log!
    System:
    CPU - Intel i7 3770k
    Motherboard - msi Z77 MPower
    RAM - Corsair Vengeance lp green 16GB 1600mhz
    SSD - Samsung 256GB 850 Pro
    HDD - WD 2.5" 750GB Black Edition
    GPU - XFX HD 7950 DD-Black Edition
    Case - H440 Green Special Edition
    PSU - Seasonic-X 750W Fully Modular
    Fans - Coolink Fans (1st fans used)
    New Fans - EKL Alpenföhn Wing Boost 2 Plus Fans
    Dazmode Darkside white LED's
    WaterCooling
    EK-7950 - Acetal+EN (Nickel) Waterblock
    EK Supremacy CPU Liquid Cooling Block - Acetal + Nickel
    EK- X3 250 Liquid Cooling Reservoir
    EK-DDC 3.2 PWM X-TOP CSQ Pump - Acetal
    PrimoChilll 1/2" PETG 16 36" tubes
    1 360 and 1 120 EK PE Rads
    Redharbinger EK 250 Reservoir Cover
    Mayhems Coolants and dyes
    This is the start of my build log and what my case looked like air cooled, before I started on the water cooling.
    This is my setup.
    Here's some pics of my fittings. Absolutely love the color.
    I then purchased:
    4 low profile plugs
    2 extenders
    1 valve
    1 5way (Multi-F block)
    All from Bitspower
    and 1 EK-7950 - Acetal+EN (Nickel) Waterblock
    Here are my 120 and 360 EK PE rads..
    The boxes, they are soooo pretty :0
    I think I might have a box fetish..
    I got a new background (got rid of that hideous white one).
    Here are some pics of my EK water pump.
    I took pictures without sleeving and then with the wires sleeved, both my husband and I sleeved them.
    I bought a Samsung 256GB 850 Pro.
    As well as a 750GB WD Black too.
    Got some shiny screws!
    I had screws custom anodized for me to match the compression fittings.
    A local friend of mine did them. Got to say he got the color spot on :)
    I will have custom anodized screws throughout the entire build.
    I bought some of the screws from Probolts too.
    Here's what the screws looked like on the rads with the compression fittings.
    It's all starting to come to come together, though these fans I got rid of. I didn't like the way they looked and the color was too much and off.
    So I decided to buy some new fans that I thought looked a lot better.
    Here are my new Alpenföhn Wing Boost 2 fans. Some of you may recognize the design of the fans, they are the OEM version of the Parvum F1.0 fans.
    Performance wise these fans are very quiet, you might as well call them dead silent.
    The static pressure also exceeds what I though they would push.
    I'm amazed at the quality and the frame, it's not hard plastic it's made out of a dense rubber material.
    So here, just like in the pics before last, is one of my new Alpenföhn Wing Boost 2 fans on one of the rads with the screws and compression fittings.
    I would say these blend much better than the last fans. No more ugly stand out grey and overwhelming yellowish/green.
    I think with these there's just enough green to compliment and it matches the case near perfect.
    Here are all my anodized screws, there will be a lot of detail in this build. :D This will help the build pop and help to even out the green and purple within my build.
    -Here's a pic with one of the anodized screws and one of the screws that came with the mounting bracket.
    -In this pic it shows both the anodized screws in and how it will look. Makes a big difference, and goes to show how every little detail counts.
    Gonna do some artsy fartsy stuff XD
    I will be changed the stickers on my fans to black with a green question mark, and also the yellow on the MSI Mpower board green.
    Riddle me this...
    Here's some pics of my Alpenföhn Wing Boost 2 fans redone and my MSI Mpower board with green instead of the yellow.
    I think I'm in love... Here's my SSD redone.
    Here's the Redharbinger reservoir cover I got. I decided to get this to not only make the Res look sleek but to dim down the color as well.
    My Mayhem dyes and Darkside LED's
    Added vinyl to my EK button badges as well.
    Put the GPU block on and added a nice simple touch of green to it. I did the the Res brackets as well.
    If you notice, I made the NZXT lighted logo purple instead of the clear. This is the build partially put together. I couldn't resist and just had to see it, especially the screws.
    Here is the memory done with vinyl. I nearly pulled my hair out with these lol but love how it turned out. It was worth the time and patience.
    Here is my cable management, this is in the begginning and changes throughout the build process but it pretty much stayed this tidy. My husband and I also redid the sleeving, I decided I wanted to go with a different pattern, and we also shortened the cables to custom lengths.
    Zip ties are a geeks best friend..
    I bent the tubes freehand to get the decired twists and turns for the runs.
    I also purchased some new cable combs to replace the old ones. i didn't like how these looked and wanted something more sleek.
    My artist sent me some pictures of the work along with steps of the process of creating the Riddler theme on the computer case. This is one of the three panels that had being done.
    1- We start by cleaning all surfaces to be painted with a wax, grease and silicone remover.
    2- Next, we mask off the back side of each panel to keep things clean.
    3- We also mask the clear acrylic window.
    4- Then we begin to prep sand the panels.
    5- Notice sanded vs un-sanded.
    6- We also use a scotch brite pad to help sand the edges and tighter areas.
    7- Everything is ready.
    8- Notice sanded to the very edge.
    9- Next, two coats of black base coat are sprayed.
    10- Now we begin the artwork portion. The supplied artwork is resized to fit the panel.
    11- In this case, the highlights are trimmed and the neon green base coat is airbrushed through it.
    12- You can see here the details of the layering process. Several different greens are used to create depth and black is used to tighten things up.
    13- Here is an example further along in the process. Things are getting much tighter and detailed.
    14- The artwork is about 80% complete. A few more details to pack in, highlights to pop out and we are ready for the matte clear finish.
    15- An angled pic shows the layering.
    Here is the fluid I used. Mayhem's pastel green with half a bottle of UV green dye added to it.
    Here are the final pics of "The Riddler". It took me over the course of nearly a year. I wanted this build to show character, be riddled with details and stand out and make a statement. I feel I have finally succeeded in this. I hope that you all like the outcome and please feel free to comment and share your opinions on the completed build. And so now I give you...
    The Riddler
    Now on to the next build..
    cobalt6700 likes this.
  2. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    Looks great. Especially that artwork :)
  3. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Hole smokes, batman!
  4. _TechPuppet_
    1 Feb 2015
    Thank you :) I wanted the build to be its own art piece. My artist surprised me, I was expecting a good job but he went beyond my expectations.
  5. _TechPuppet_
    1 Feb 2015
  6. bionicgeekgrrl
    1 Oct 2009
    You're welcome. I think you succeeded in that goal nicely, the artwork really stands out.
    And yes, I'd agree your artist did a great job too!
  7. _TechPuppet_
    1 Feb 2015
    Thanks again. I'm working on another one right now and this one will have an airbrushed paint job as well.
  8. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    superb
  9. Gazmtk
    Gazmtk What's a Dremel?
    3 Dec 2014
    Totally BLOWN away!! very well thought out, you must be extremely proud of yourself :)
  10. bionicgeekgrrl
    1 Oct 2009
    I'll keep and eye out for it :)
  11. stealth80
    stealth80 Minimodder
    1 Feb 2015
    Looks awesome, I was just thinking about a green themed build last night, maybe some sort of matrix theme, but your build looks awesome!
  12. _TechPuppet_
    1 Feb 2015
    Thanks
  13. _TechPuppet_
    1 Feb 2015
    Thank you, I put a lot of heart and soul into it so yes you can say I'm very proud :)
  14. _TechPuppet_
    1 Feb 2015
    Thanks, and I think the Matrix idea would be cool. Add some binary code to the case, green LEDs, the works. :) I have so many ideas I want to do it's hard to choose which one to go with next. Lol
  15. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    My favorite H440 build :cooldude:
  16. _TechPuppet_
    1 Feb 2015
    Thanks Bill :D that means a lot. The only thing left to do for this build is to buy one of your side panels ;D cuz the one it comes with just won't do. Scratches too easy, and can't clean it at all. I want to get your panel so when I buy the Dreamhack tickets for Austin Texas, which will be available on Sep.15th (so stoked!), I'll be able to show off my build there with a nice clean panel. Course I'll probably keep the panel boxed till about a couple days before the event in May, that way it looks its best.
  17. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    That's totally beautiful.
  18. _TechPuppet_
    1 Feb 2015
    Thank you :)
  19. coffinator
    coffinator What's a Dremel?
    2 Jan 2011
    techPuppet, this has to be my favorite non scratch built case I've seen on bit tech. Your attention to detail and planning is spot on. Then again I may be partial to the riddler character. have been since I was little. I still have the limited edition Riddler cup from Mcdonalds when they sold cups for the 1995 release of Batman Forever.
  20. _TechPuppet_
    1 Feb 2015
    Wow thank you I really appreciate the compliment. I used to collect those as well when I was younger. Not sure what happened to them but they probably ended up in a yard sale :( I regret not keeping half the stuff I had when I was a child.
