"THE RIG" A SoulsEnd project (update 1-25-04)
Discussion in 'Project Logs' started by SoulsEnd, 12 Jan 2004.
  1. SoulsEnd
    SoulsEnd What's a Dremel?
    23 Aug 2003
    First lets get the name thing out of the way...THE RIG...
    After designing the front acrylic panel (which you will see in few) I realized that it resembles the front end of a large diesel rig. So it stuck with me…”RIG”
    The purpose of THE RIG is to be a small LAN game server. Incorporated into it will be a 16-port switch, 14 inch LCD monitor and a wireless keyboard/mouse combo. It will only have one cord in the back and that’s for its 110volts. All motherboard connections will be done inside the all-custom aluminum chassis. So with this in mind, lets start at my workshop and hack some aluminum.
    My tool box from the days of being a mechanic…
    Miter saw with metal cutting wheel…Makes cutting so much easier.
    Lots of aluminum pieces…Kinda like a jigsaw puzzle.
    A shot of how the corners will join.
    All corners getting drilled, tapped, countersunk ect….
    A shot of one corner done, seven more to go…
    Decided to tap some corners to see if my measure 3 times cut once idea worked…It did. I wont bore you with me connecting each corner…one was enough!!!
    The only thing pre-fab about this cube was the panels. I managed to get my hands on some aluminum side panels that no longer had homes (how sad). Well they have a home now. I had to cut into the cube chassis for the panel lock tabs.
    After all locking tab holes were cut, the panels were test fitted.
    I Received a large amount of the goods needed to proceed with “THE RIG”
    Pictured below:::
    2 80mm rads
    2 UV 80mm fans (not sure if they will be used)
    16-port unmanaged switch
    Wireless keyboard/mouse combo
    14” LCD (already had that)
    Enermax PSU
    10ft of clearflex
    Also received my solid black acrylic for the front panel. See why I picked the name now???
    I have a good idea of how everything is going to lay out inside but because nothing is concrete at this point…its on a need-to-know basis. :D The LCD however is kind a self-explanatory.
    I decided to to a test fit of the LCD.
    That’s all for now folks…Check back soon for more updates.
  2. borumas
    borumas What's a Dremel?
    22 Sep 2003
    :thumb: Lookin' real good so far man, keep it coming, I'll check the other forum to see if you posted there as well. :rock:
  3. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    That sliding LCD is ****ing awesome. :rock:
  4. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    This looks like a very cool project. Now, I just have to read the text instead of just looking at your pictures
  5. SoulsEnd
    23 Aug 2003
    I would be lying if I said I haven’t "skimmed" a thread before to look at pics. :worried:
  6. 3vil-Grin
    3vil-Grin What's a Dremel?
    25 Jun 2003
    Wow...great idea for a case!!!!
    Well cant wait to see more!!!!
    Oh and what type of lcd is that?! Just curious...
  7. SoulsEnd
    23 Aug 2003
    Its a 14" mag I picked up from bestbuy during the day after Thanksgiving sale for $100 USD. Its like it was design for this app. :D
  8. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    love qube's!
    the lcd looks sweet, kinda like the rack mounted we got at work! :rock:
    Cant wait to se the result!
    GL HF
  9. Fluba
    Fluba What's a Dremel?
    20 Jun 2003
    :eek:
    wow wow wow wow :eeek: :eeek: :eeek:
    i LUB it
    have you thought of windowing the top side above the LCD so you can have it on without getting it outta the case? thatd rox :) :brrr:
  10. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Excellent idea with the side panels :thumb:
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    looks very nice - any etching/windows to come?
  12. SoulsEnd
    23 Aug 2003
    My plan is to do something like this (as seen on one of my previous cases) just on a much larger scale.
  13. SoulsEnd
    23 Aug 2003
    I would like to have matching window designs on both the left and right side panels. The "jury" is still out on a design though. :sigh:
  14. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    OMG those LCD mods are craaaaaaaaaaazy sweet. Nice shop too, and the panels look awesome. Consider yourself subscribed!
  15. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    details on how you did the small one in teh drive bay?
  16. t.n.
    t.n. What's a Dremel?
    26 Dec 2003
    damn thats nice :jawdrop:
    anyway, where did you get the side panels?
  17. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    wow looks like a nice project
    good work :rock:
  18. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    I covet your tool bench sir..... the quality in the construction so far is impressive... welcome to the boards! :rock:
  19. SoulsEnd
    23 Aug 2003
    How about I do you one better...SoulsEnd Drivebay LCD guide
    Thanks for the props guys...means alot coming from the bit-tek crew. Just got my casters and the hardware needed to finish the LCD portion of the mod. May have updates tonight. :thumb:
  20. SoulsEnd
    23 Aug 2003
    Im local to an online vendor and do some part time work for them. They had some spare panels and offered them to "THE RIG" project. :D It was either I take them or the dumpster.
