The Sound of Silence - Everything Water cooled - Update Feb 23
Discussion in 'Project Logs' started by Alvin, 2 Feb 2005.
  1. Wow! Sweeet watercooling thang goin' on bro!
    If this project suddenly ends and Alvin doesn't appear on bit-tech, it's prolly because his PSU got soaked ROFL!
  2. frodo
    frodo What's a Dremel?
    1 Nov 2003
    hmmm, ont think id laugh 'bout that, i really want to see this finished!
  3. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    I doubt his psu got soaked. He probly finished the project or just put it on hold because he probly has work and general life geting in the way.
    Lets hope he updates the thread.
  4. angelorus2000
    angelorus2000 What's a Dremel?
    14 Nov 2003
    i like all watercooled and the spliter idea
    i want updates :D
  5. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    i hpe you know that a mix between copper blocks and aluminium blocks makes corrosion witch is a bad thing
  6. 2800@2.5ghz
    2800@2.5ghz What's a Dremel?
    23 Mar 2005
    yea, but adding some water wetter will stop corrosion.
  7. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    not stop it. only decrease it
  8. Alvin
    Alvin Guest
    Hi there all,
    Jaguarking11 got me back on track, by PM'ing me.
    I have been really low on money, and I have really wanted to find a pump that does not vibrate.
    Then it turnes out that my own youngest brother has found the solution!
    The smallest Danfoss pump... or was it a Grundfoss pump, anyway they are professionel water pumps, not just aquarium pumps. He's now using it with his two Zalman Reserators, after frying four of the original pumps.
    I'll get back with the right data later, it's too late to wake him up now (00:39 here).
    Now I just need to get some cash!! Where was it that I stumbled across that gold nugget?
    Oh, it was in a dream. :waah:
    Well, hope to be back later this fall. Gotta go on holiday with the kids for the next three weeks.
  9. frodo
    1 Nov 2003
    danfoss pumps are really good, they are designed for boats (most of them) and are REALLY good solid pumps, i want to source one for my project, as they dont vibrate too much, and also generate less heat than my l20 :mad:
  10. Alvin
    Alvin Guest
    Talked to my brother about the pump.
    It is a 230V Grundfos UP 15-14-B inline pump with 1/2" threading.
    Here is a link to the Grundfos site about this line of pumps
    Then select: "Product Range and Technical Data".
    I have also located a supplier, though it is a danish supplier, and his website is only in danish. His website does not allow a direct link, but by clicking both of the following links, I was able to create a direct link.
    Open privatgrossisten.dk Web shop and then Open a direct link to the Pump
    This is the online store that my brother used. It is an online store only, but as it turnes out he lives less than 5 minutes from me, so I am sure I can talk him into shipping world wide, if needs be.
    I have not seen the pump my self, but it is said to be the size of the largest of the Enheim pumps.
