Windows the stuff in vista
Discussion in 'Software' started by Elspuddy, 16 Oct 2007.
  1. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    s ther any way of removeing some of thius stuff in windows, i.e dvd maker , contacts etc.. ?
  2. culley
    culley What's a Dremel?
    12 Jul 2006
    Why would you want to do that?
  3. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    because i dont use half this suff ;)
  4. culley
    12 Jul 2006
    Oh right, your worried about hard drive space or just that you don't see no point in having it there. I doubt there are ways to remove it, It's not on basic, prehaps if you don't use half the stuff on Home Premium or Ultimate maybe you should downgrade :D
  5. capnPedro
    11 Apr 2007
    Control Panel -> Programs and Features
    Turn Windows features on or off
    That any good?
  6. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    just don't see no point in having it there, it's sfotware i'm not going to use ;)
    as for hard drive space, i got a long way to go to fill up a 500 gig drive :p
  7. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    nope, none of the programs are listed there
  8. Mister_Tad
    27 Dec 2002
    Just remove the shortcuts and/or registry entries?
    You don't need the negligible space that they consume, and they don't use up any resources if you're not using them, so removing visibility of them should be as good as removing them all together.
  9. capnPedro
    11 Apr 2007
    Type
    services.msc
    into the start bar to bring up the services config. Disable any services you don't want running to conserve CPU cycles and RAM. Otherwise, just follow Mister Tad's advice.
    Oh, and be careful not to disable something that's needed.
    And msconfig.exe is useful too.
  10. koola
    koola Minimodder
    11 Jul 2004
    Try vLite which is just like nLite but for vista.
