Scratch Build – In Progress The Tempest
Discussion in 'Project Logs' started by exiled, 6 Jan 2013.
  1. exiled
    exiled What's a Dremel?
    17 Jul 2012
    Hello All Wanted to build a case for myself till my son was asking around christmas for a pc so i figured id scrap my build which was already started to build another case just this one is a bit different its to house both a matx and a itx in the same case matx is my pc and the itx is going to be my sons so after 4 days of designing i came up with this
    And with out keeping you hanging to long i started building friday since i have to build at my dads house progress has to be staggered days i can get there to build i try but at the same time i have to do things like keeping the project a secret from him so hopefully its kept from him till around February 19 his birthday so now for those seeking more pictures here we go
    test fitting the mock up itx mobo
    another shot
    last shot of itx testing
    took me quite a while to build the frame only working with limited tools at moment ie: drill press, riveter, metal shears, ruler and plan at moment
    this is with the itx and matx mock up boards test fitting before i hard mount ether of them
    had to ask for help for this shot couldn't take the picture while holding the matx
    but that's where I'm at so far will be going back to my fathers tomorrow to work on some more and hopefully i can get the frame fully complete tomorrow then can start making the templates for the plexiglass hope you enjoy the write up so far. :)
  2. exiled
    17 Jul 2012
    ok got some more progress done today itx motherboard bracing testing [​IMG]
    having issues mounting the matx [​IMG]angle from bottom well testing mother board tray [​IMG]
    all i can do at moment need to buy more aluminum turns out i didn't buy enough [​IMG]
    well guys tell me what you think. :)
  3. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    ITX? Looks like it'll have a lot of deadspace
  4. exiled
    17 Jul 2012
    both ITX and MATX are in the plan along with 2 x 5.25 8 x 3.5 hd 4 x 2.5 ssd 2 x psu 4 x 120mm fans maybe water cooling to come led lightning but may have space left over but for my first build if its too big i will learn from the attempt
  5. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Looks good to me love big cases ! Will keep an eye on this build for sure subbed:thumbup::D
    Sent from my Nexus 7 using Tapatalk HD
