Apple The time has come.. (Upgrade)
Discussion in 'Software' started by Sam0r, 27 Aug 2006.
  1. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    The time has come for me to upgrade.
    My powermac g4 isn't too speedy anymore, and I'm looking for a new machine.
    Currently, I have two options.
    Ebay a powermac g5 (Dual processor) or save for a few months and get a Mac Pro.
    But, I'm just wondering if I'd need the power of the Mac Pro, I do quite a bit of webdesign (Photoshop and Dreamweaver) and sometimes I master audio tracks for friends bands (Cubase).
    Currently, my g4 does it all well, but its still pretty sluggish.
    I think I'd be better off ebaying a G5 and I can easily afford one, but I don't think I could afford a Mac Pro just yet.
    What do you guys think?
    Also, how much do you think I'd get for my g4? (Specs in sig)
  2. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    No idea on prices for a used G4. I think a Mac Pro is overkill. Unless for some crazy reason you want Bootcamp, I would get a Dual G5. No way you would regret that. They are amazing computers, I was eyeing at one a few weeks ago aswell, but they are so expensive.. even used.
    Good luck!
  3. Mimic
    Mimic What's a Dremel?
    19 Jul 2004
    there is 2 G5's in the refurb store on apple atm, might be worth a look?
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    it might be worth just saving the extra amount to get a new mac pro... they're unbelievably fast
    though depending on what programs you use and if they're universal binaries, it'll make a difference on how fast it seems
    i know the g5 vs intel iMac is a very noticable difference in speeds
  5. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    MP, upgradability, and in a couple more years, the G5 will be rendered useless.
  6. Sam0r
    24 Jun 2005
    I mostly use Dreamweaver and Photoshop, which currently aren't universal, which is a downer.
    I was thinking about buying an iMac, but I could really do with dual monitor (I know the iMac supports it, but I'd rather use my two 19" wide tft's.) and 5.1 sound (I'll be putting a revolution 5.1 in the G5 if I go that route).
    A mini is completely out of the question due to the max of 2gb ram and no (decent) dual monitor support.
    I think a G5 would be the best bet, as its cheaper than a MP, I'll have to see how the money goes.
    A refurb G5 isn't a bad idea, if I had the money right now I'd buy one, but I don't.
    Another thing about the MP is the ram, its amazingly expencive, using FB dimms was a good idea, but I'm not paying the stupidly high price for FV dimms!
  7. Sam0r
    24 Jun 2005
    Due to the new iMac pricing and Core 2 Duo chip, I think I'll get one of those and run it along side my 2005fpw.
  8. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Yeah, I wouldn't buy a non-intel mac now. Surely even an Intel Mac mini would be better than the outdated G5?
  9. Sam0r
    24 Jun 2005
    I'd get a mini for sure if I didn't rely on dual monitor so much.
  10. K
    K 528491
    31 Oct 2001
    Mac Pro... By miles. If you can, get one. You'd be crazy not to, if you can.
  11. rgkgraphix
    rgkgraphix What's a Dremel?
    16 May 2006
    MacPro!!!
    I have the dual 2.6 and that thing boots OSX in no time. I didn't think the Adobe apps were that sluggish but I was coming from a G4 and an Athlon 2500+ also I haven't really put it to the test yet.
    I hope memory prices come down soon though.
