Case Mod - Complete The Tombstone
Discussion in 'Project Logs' started by MPC, 3 Sep 2018.
  1. MPC
    MPC Minimodder
    24 Oct 2015
    The time has come to start a new project in collaboration with the well-known world brand Thermaltake. The theme of the project was quite easy to choose from as we immediately thought to present it at the event on information technology and gaming, Lucca Comics, which will be held in the period of late October-early November. Just in this period there is an important party in America and also in other parts of the world, Halloween. Well, the theme of the project is based on tetra and gloomy and the name is "The Tombstone". Inside the fantastic chassis, Thermaltake View 91 TG, will be implemented of the scenic material that reflects the main theme. Skeletons, dark setting and dark purple color of the loop of liquid cooling will decorate the inside of the chassis while on the front there will be a headstone with a skeleton with sound and movement. The pump-tank combos positioned on the sides of the headstone will simulate the grave stone lighting. Now we just have to start the project showing the spectacular material that Thermaltake kindly gave me for the realization of the project.
    Stay tuned ;)
  2. MPC
    MPC Minimodder
    24 Oct 2015
    Asrock motherboard !!!
  3. MPC
    MPC Minimodder
    24 Oct 2015
    Apacer SSD and RAM !!!
  4. MPC
    MPC Minimodder
    24 Oct 2015
    Inno3D graphic card !!!
  5. MPC
    MPC Minimodder
    24 Oct 2015
    Realization of mahogany wood supports to fix the two cylindrical tanks symmetrically to the center of the headstone. The tanks will simulate the grave stone lighting.
  6. MPC
    MPC Minimodder
    24 Oct 2015
    Cutting to size and drilling to pass the cables of material that simulates a tree with its bark.
  7. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
  8. MPC
    MPC Minimodder
    24 Oct 2015
    Test of insertion inside the chassis with skeleton and barbed wire. Finally gluing.
  9. MPC
    MPC Minimodder
    24 Oct 2015
    New front plate in 4 mm thick plexiglass to replace the original one in tempered glass where processing is more complicated. Drilling diameter 18 mm for passage of tubes to tanks. Finally, visual evidence of blocking supports for tanks on the sides of the headstone still to be inserted on the front.
  10. MPC
    MPC Minimodder
    24 Oct 2015
    Execution of the same holes made on the front plate that will host our tombstone in all its beauty.
  11. MPC
    MPC Minimodder
    24 Oct 2015
    Creation of a rectangular basin to contain soil with dry saplings. The tank will be placed on the bottom of the chassis next to the power supply and will be an integral part of the tetra landscape creation.
  12. MPC
    MPC Minimodder
    24 Oct 2015
    New dress on the video card.
  13. MPC
    MPC Minimodder
    24 Oct 2015
    Insertion of Riing Trio fans on radiators and overall visual appearance of the interior.
  14. MPC
    MPC Minimodder
    24 Oct 2015
    Insertion of headstones with tanks.
  15. _Prometheus_
    2 Jul 2017
  16. MPC
    MPC Minimodder
    24 Oct 2015
    Loop finished!
    Start inserting power cables and doing some cable management.
  17. Cheapskate
    13 May 2007
    OK, now it's just getting silly. :lol:
    _Prometheus_ likes this.
  18. MPC
    MPC Minimodder
    24 Oct 2015
    Only according to your opinion while for others it is wonderful. Bye ;)
    Final photos with lights on and PC off.
  19. _Prometheus_
    2 Jul 2017
    In my opinion there aren't enough figures from Lego and Bengal lights.
  20. MPC
    MPC Minimodder
    24 Oct 2015
    I still have to edit the photos with the light system. There is no Lego component.
