Modding The tools of modding
Discussion in 'Modding' started by The_Beast, 20 Aug 2007.
  1. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    We should make a list on what tools are needed and others that are nice to have but aren't necessary
  2. DSquareD
    DSquareD What's a Dremel?
    24 Nov 2005
    The trusty favourite...the mighty dremel
    hand saw, rotary saw, router (if you're lucky enough to own one), screw drivers + and - and *, electrical, tape, masking tape, duck tape, super glue, wood glue, pop rivet gun, the list is really endless...all depends on what you need for your mod...
  3. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    nice toolkit:
    various screwdrivers (inc jewelers),pliers, sidecutters, handsaw
    lightweight compact cordless screwdriver is very nice to work with - reduce fatigue doing repetitive screwing, and a drill chuck to fit the cordless screwdriver & drill bits
    an assortment of cable, different gauges, colours, cores, etc
    an assortment of sleeving & heatshrink (use hairdryer not a lighter to shrink)
    an assortment of resistors, diodes & vregs
    soldering iron & solder
    files (flat/round/big/small) various sandpaper grits, piece of glass to sand on & sanding blocks
    thermal greases & adhesive & isopropyl alcohol & rags
    lots of time, or better yet a time machine, and money is good aswell
  4. Guest-23315
    Guest-23315 Guest
    Jig-Saw
    Tin-snips
    a torch
    files
    sandpaper
    drill
    polish
    hacksaw
    and occasioanlly the dremel
  5. The_Beast
    21 Apr 2007
    taps if you need to thread anything
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    QFT.
    Thread icon changed, this isn't a guide. :nono:
  7. Teyber
    Teyber ******
    18 Mar 2007
    Scroll saw, Drill press, TAble sander, Jig saw, Hand drill, Dremel, Mouse sander, Files, Needle files, lots of bits/saws/drill bits, Clamps,lots of sandpaper, Paint, and common sense. O and a table saw/mitre saw doesn't hurt either. Mill/lathe/box pan brake are all same damn nice luxories.
  8. n00btard
    n00btard Go away
    23 Jul 2006
  9. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    necessary:
    riveter
    drill
    dremel
    screwdrivers
    soldering iron
    pliers
    sidecutters
    wish i had:
    jigsaw
    bending brake
  10. Teyber
    Teyber ******
    18 Mar 2007
    wait why is a torch necessary?
    WIsh i had:
    9x20" lathe(x-mas? plzzzz mom i love you mom plzzz)
    table saw
    mite saw
    router+router table
    (hopefullly all for christmas)
    I wish i had a bending brake... Whats a cheap solution for bending?
  11. Cheapskate
    13 May 2007
    2 2x4s, some vices, and a hammer.:D
  12. ComputerKing
    8 Sep 2006
  13. willyolio
    willyolio What's a Dremel?
    17 Feb 2007
    perhaps we should categorize and organize these:
    1. all-purpose
    2. aluminum (scratch build)
    3. acrylic (scratch build)
    etc...
  14. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Are you volunteering? =P
    I agree, though. There should be all-encompassing article/wiki/etc on modding tools, with different focuses being placed on tools for different level modders and different materials.
  15. TGH-odin
    TGH-odin Swedish Modder
    31 Aug 2007
    This is my arsenal when modding:
    Dremel Copy
    Screwdriver
    Cordless drill
    Wired drill - alot stronger
    Jigsaw
    Files - correct in english?
    Hand saw for metal
    Metal sizor - Donno enligh word :)
    Soldering station
    Gluegun
    Riveter
    Well, thats about it.
  16. Stuey
    20 Jan 2005
    For the "Metal Sizor" would it be possible for you to link us to a photo?
    "Files" is correct in english. Also, a metal-cutting hand saw is typically in the form of a "hacksaw," or hack saw I forget which is correct.
  17. Guest-23315
    Guest-23315 Guest
    I guess Metal Scissors would be Tin-Snips.
  18. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    an article on this subject is a good idea and something to look out for in the future. :naughty:
  19. TGH-odin
    31 Aug 2007
    Metal Sizor(?):
    Mine looks like this:
