Scratch Build – In Progress The Ultimate Computer Desk - 2 Integrated Desktops (September 1)
Discussion in 'Project Logs' started by ultimatedesk, 29 Nov 2010.
  1. ultimatedesk
    ultimatedesk New Member
    18 Nov 2010
    2nd Hole!
    I finally got around to putting the second hole in the desk surface area (Since the desk is composed of two sheets of plywood, there are two holes needed, with the "top surface" needing a hole that is .5" larger all the way around, so the "bottom surface" supports the piece of glass which covers the gaming computer).
    I took a few more detailed pictures compared to last time.
    As with before, I started by cutting out a rough shape with the jigsaw. I was able to get within .5" comfortably of my marked lines. Sometimes if you rush the jigsaw, your cuts can get a little squirrely, so I was playing it safe. This is the top surface, so no screwing up here!!
    I then took an extra dose of patience, and went in straight to the corners with the jigsaw. This is a step I did not take last time, and I made a mistake with the router because of this.
    I then took the router and pressed the bit right into the corner, and clamped a straight-edge on behind it. This is how I set the distance from the bit to the straight-edge. I repeated the same for the other side.
    All it took was a good solid pass from right-to-left and I had a very clean straight edge without having to go all the way into the corners, where mistakes can be made, since it is quite difficult to see where the actual router bit is when the tool is running.
    Unclamp, reset router, reset clamps and straight edge, lather, rinse, and repeat:
    This hole had a very small margin of error overall, and I am very pleased with the result. The jigsaw is an incredible versatile tool and can be very accurate, as long as you have patience. This one corner is the only one that will need a touch-up with a file and/or sandpaper, and you can see, it's only going to need less than a 16th of material removal!
    And that's all I had time for in the shop that day ;) Enjoy some of my mess!
    Until next time - I have some images in the queue, but I haven't quite gotten around to resizing them just yet ;)
  2. Skorchio
    Skorchio New Member
    16 Oct 2009
    This look insane :) Just the way i like project :)
  3. jprykov
    jprykov New Member
    29 Oct 2010
    i liked it how its well planned and visualized. keep the updates coming! :) what color are you going to use?
  4. matiss
    matiss Member
    24 Jun 2010
    Very nice idea and good way of work so far.
  5. Alexandros
    Alexandros New Member
    10 Jan 2010
    Very ambitious project you got there. Also glad to see you like my Ares model ;).
    Just wondering, are you actually going to get 2 Ares, or did you just use them as reference for the sizes?
    Good luck with all that wood :).
  6. ultimatedesk
    18 Nov 2010
    Thanks Bit-Tech
    Ha, insane is definitely one word I've heard a few times about this project - I'll show you! I'll show you all! It's going to be insane all right - INSANELY AWESOME ;)
    Thanks jprykov, the updates take a surprising amount of effort and time to do, so I'm glad you've enjoyed them up to this point! I'm planning on doing a dark black/red stain, like a cherry mahogany I think it's called.
    Thanks matiss!
    Wow very cool, thanks a lot for the model Alexandros. I am not necessarily planning on using a pair of Ares - I selected that model because they were the largest video card models I could find, so they are just used for reference.
    Thanks for the encouragement everyone - stay tuned, I've got a few updates in the pipeline!
  7. ultimatedesk
    18 Nov 2010
    Desktop Chop Shop
    Hey everyone, it's been a little while since my last update, so here are a few snapshots. As some of you might know, I've been a little held back in the project due to not having selected my motherboard I/O plates and motherboard trays. Without having the actual items, I couldn't make the appropriate measurements to make cut-outs in the back of the cabinets, and therefore, was unable to make the dado cuts due to worry about everything not fitting properly.
    So I scrounged through some old desktop systems I had lying around, emptied their components into my bins, and decided to take apart their chassis in search of some good motherboard tray and I/O parts.
    So - off to the spooky basement with a pair of chassis, my trusty drill and dremel.
    Having never drilled rivets out of a case before, I wasn't entirely sure what to expect. At first, I started with a bit that was a little bit small, so the rivets came up onto the drill bit itself and got stuck on there pretty good. Eventually, I moved to a bigger bit, and all it took was one good squeeze of the trigger and the rivet would come right out nice and cleanly.
    Starting to rack up some parts here
    You can see in the image above that the I/O and PCI Plate is built right into the back of the desktop chassis - this is unfortunate, as you'll see in some future photos, my other case actually had a modular I/O plate. I'll have to take the dremel to that part to get what I need.
    Time to grab the pliers...
    Here is the shot of the back plate of the other desktop chassis - see how the I/O plate was actually riveted in, and not pressed as a whole back sheet like the other one? Soo much easier to deal with.
    That was a pretty fun experience taking apart the cases. I've got a bunch of scrap sheet metal now too - wonder what interesting projects I can come up with to use them...
    I need to dremel out the section that I need, as well as the power supply brackets.
    Huh.. that actually didn't work out too well, at least, not the way I would like. I'm going to take these parts to the shop to see if there are any better tools for getting nice clean lines.
    Until next time!
  8. ultimatedesk
    18 Nov 2010
    Desktop Chop Shop Part 2
    Sorry for the lack of updates lately, things have been overly busy lately with the Christmas season getting into top gear.
    I had some time to take those motherboard tray and I/O Plates to the shop to try out a few tools / techniques for shaping them into something I actually like.
    First off, yes, Mike and I tried using the nice Dewalt Jigsaw, but the Mastercraft metal blades we were trying to use just wouldn't stay in the darn clamp. It would cut like butter for maybe 10 seconds and then bam, the blade would fall out of the bottom of the jigsaw onto the ground. Not sure what was going on there.
    Next up, we tried this neat little Mastercraft oscillating tool with a metal blade as well, but no such luck. Couldn't figure out a good way to clamp down the metal tray, so it just vibrated it like crazy instead of actually cutting.
    Our next contestant was an air compressor powered cutting wheel, which, was ultimately less accurate than the dremel, and just as slow.
    So we took out the big gun, the sawzall.
    Ha, no, just kidding. It wouldn't work even a tiny bit for a piece like this.
    In the end, you know what ultimately worked the best?
    Yeah, a hacksaw. Go figure.
    Anyways, here you can see my mangled I/O plate for the motherboard. It's not a pretty sight at all in my opinion.
    This is the nice I/O plate that I didn't even have to do anything except drill out a few rivets.
    I think I'm going to have to come up with a better solution for this. We'll see shortly ;)
    Hope everyone who is getting snow is enjoying it, I know here in Ottawa, it's been a pretty crazy few days!
    Stay tuned for more updates, will be spending some time in the shop this week and working with WOOD!
  9. Xye
    Xye New Member
    21 Nov 2010
    What I've always wanted to do is have a glass desk with a monitor underneath so that I can look down at what I'm doing as well as having monitors straight in front of me .... or maybe i'm just weird...
  10. ultimatedesk
    18 Nov 2010
    Drawer Work
    Heh, I don't think that's weird at all - that would be pretty cool. I think I've seen some receptionists with desks like that so they don't have a bulky monitor on their desk. It's even more reasonable to do that now with LCD screens being so thin, they won't interfere with your leg room much!
    I had a bit of time in the shop this week to work on getting my drawers up to speed. I decided to take the advice of a fellow forum member and add "false fronts" to my drawers so that I can attach the "real fronts" using screws by screwing from the inside of the drawer, so I wouldn't have any screw heads to cover up on the outside.
    Here they are, with my roughed out false fronts - I happened to have 3 pieces of wood almost exactly the size I needed.
    Time to take out 'ol trusty
    A quick test fit, and all 3 fit perfectly
    Add a bit of glue, and some trusty clamps, and we've got ourselves the beginnings of some false fronts!
    All 3 of them fit rather nicely. I think they helped square out the drawers overall as well (Even though they were only out of square by around 1/16th of an inch).
    So, I've got some time for the glue to dry. I'm not sure if anyone can remember this, but in my original cut sheets, I had planned on cutting out a specific piece of wood using the wood that I jigsawed out of the desk surface.
    Here's that piece:
    Not, exactly.... square..
    So I take this nice little protractor attached to a table saw slide - it's set at 90, so here we go!
    I do 2 sides, and then use the actual table saw fence to square out the other 2, but something just doesn't seem right..
    It's not really square. What's going on here?
    Aha! Looks like the protractor was a little bit off, resulting in a shape one step closer to a diamond as opposed to a square. After a bit of readjustment, I redid that bit and cut it to size - it's the drawer face for the large drawer.
    Now that the glue is settled, I decided to throw a few screws into the false fronts.
    Awesome. And solid too!
    Now, this is kind of embarrassing, but I had to go back and fix a mistake I made in my initial cuts. This piece of wood was supposed to be 20" x 28", but it ended up being more like 19.8" x 28". It may not seem like much, but this is the back piece to the left-hand cabinet. I would have to adjust the width of all 3 shelves if I were to continue using this, and I've got the space already pretty tightly packed with computer components on the top shelf.
    So... don't do this at home, just cut a new piece of wood (I didn't want to cut into a new sheet of 4x8 just for this one piece...)
    This piece looks like a good fit...
    No one will see it, because it'll be in the back, but you will all know. So... let's just forget that ever happened, ok? ;)
  11. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Forget what? ;););)
    This looking really good, cant wait for the next update.
  12. ultimatedesk
    18 Nov 2010
    Desk Gluing Time
    Thanks M7ck, ask and ye shall receive! Hopefully the updates get a little more exciting in the coming few weeks as I begin the actual ASSEMBLY ;)
    I decided it was time to glue the two surfaces together that would comprise of the actual desk surface and take a break from working on the drawers for a while.
    Here it is, the first piece. At first I wanted to lay it face down, so I could evenly distribute screws through the bottom, but in the end, I went face up so I would protect the surface, and it would be a LOT easier to line up the holes.
    I threw on the top layer, lined them up, and thought to myself: Hmm, I wonder what it'll look like with the top shelf stacked on:
    Pretty cool. This was the first time I had actually pulled a chair up to it to get a real grasp of how big this desk is going to be. I was pretty psyched.
    Just a note, the two pieces of wood on each end holding up the shelf will actually be the inner supports (ie, pushed inwards towards the middle of the desk a foot or two), and the cubby holes on the outer ends will support the long shelf. The long shelf also has to be trimmed a couple inches, it won't reach right to the end of the desk.
    This next part was really quite a challenge on my own.
    I lined it up as best as I could (According to the holes that I cut out, since the edges are easy to trim later), lifted one end with a mighty, strong arm, squirted as much glue as I could with my other arm (And only as far as I could reach!), put it down gently, ran to the other side and repeated.
    Let me tell you - with the amount of glue I put down, and the fact that each side weighs 20-30 pounds - it did NOT want to slide around easily to get into perfect position.
    In the end, I had to muscle it around a bit to get the holes lined up satisfactorily.
    (I spoke with a couple friends about this afterward, and one of them suggested making some pilot holes and screwing in a few screws BEFORE the gluing, and then retracting the screws so that just the tips go through the bottom board. That way after the glue is put down, you shuffle around the top board until the tips of the screws find the pilot holes, thus, eliminating the issue of getting proper alignment before the glue becomes too tacky.)
    I then threw some weight on top of the table, attached as many clamps as I could find, and started putting some 1.25" screws through the bottom.
    A few clamp shots of the hole - everything lined up pretty much perfect. 1/2" on the left and right, 1/2" at the bottom, and I think just a little under 3/4" at the top. (The size of the lip between the upper and lower holes)
    I wasn't satisfied with the way the clamping was going on lengthwise on the surface. I didn't have enough clamps to place them every half foot, so luckily, Mike had some of these nice, big, cedar logs lying around that I re-purposed temporarily.
    The end result turned out quite nicely. The hole was lined up properly. There is only a small overhang / underhang of maybe 2/16's of an inch on two of the edges of the surfaces that should be easy to correct with a flush-bit on the router later.
    We'll take a look at them next update! Thanks for staying tuned!
  13. ultimatedesk
    18 Nov 2010
    Start of Drawer Trim
    Hey all, hope everyone had a good Holiday!
    I got a chance to do some work on the drawer face trim - this was my first time doing solid wood trim.
    I cut a nice piece of maple into 1/4" strips, glued, and sanded. I only did one piece this time, as I am not totally sure that this is the way I would like to go.
    Something about the trim not meshing quite well with the plywood.
    First, I set the table saw to the right width:
    Measure 3 times, and you get a nice solid cut:
    Made a few strips:
    Cut, glued, and clamped on the initial pieces of trim. The trim pieces were about 2/16's of an inch wider than the plywood, which is great, since there will be no voids, though, I'll have to do quite a bit of sanding:
    Took the sander to the top and bottom:
    Overall, it looks pretty good. I'm still not 100% certain about it, however. I'm thinking there is a strong possibility I will go with solid maple for the drawer faces.
  14. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
    nice job! what sort of camrah are you using?
  15. DeadP1xels
    30 Nov 2009
    Love watching wood working :)
    Such an art to get something looking good
  16. Marcos_Viegas
    Marcos_Viegas Member
    6 May 2010
    Amazing projetc!!!
    Great work!!!
    Congratulations!!!
  17. sc0ontz
    sc0ontz I'm a modder... I guess... :D
    30 Aug 2009
    here is some good wood works... nicely done mate!
  18. ThirtyQuidKid
    ThirtyQuidKid Member
    11 Jun 2010
    Will be glad to see the final product. Somethiong I have been thinking about for a long time.
  19. k.3nny
    k.3nny Active Member
    27 Jan 2010
    Thats some nice craftmanship!
  20. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Great work, have thought about doing something similar myself, looking forward to finished article :D
