Case Mod - In Progress The "URBAN SNIPER" Project
Discussion in 'Project Logs' started by mnpctech, 21 Jun 2009.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    or Pigeon droppings? :D
    Thank you NZXT for sponsoring this build with your new "Sentry 2" touch screen fan controller, retails for $29.99 at Newegg
    NZXT Product Specifications
    Video demonstration of the first model of the Sentry 2 sample I received in July 6th, 2009. Note the volume of the "Microwave" sounding beep has since been lowered on the current available models.
    Mach likes this.
  2. mnpctech
    21 Apr 2003
    more photos..
  3. Interloper
    Interloper Faux Pro Modder
    17 Jul 2009
    Definitely keeping my eye on this one. Your work is truly amazing!
    Go Minnesota!! LOL
  4. The boy 4rm oz
    10 Apr 2008
    I was really keen when I saw these fan controllers for the first time but now that I see actual pics (not the NZXT photoshopped ones) it appears to be that little bit to bright and blingy for me :(, still looks awesome though :D.
  5. mnpctech
    21 Apr 2003
    Thanks Interloper!
    It's a nice unit, esp after they reduced the beep volume :thumb:
    The faceplate of the Sentry 2 will also be painted
    Taping off leds on the Target front intake grill
  6. jhanlon303
    7 Sep 2006
    Bill,
    You got Tree Frog turds on your parts:
    john
  7. RuSGaMeR
    RuSGaMeR No Pain No Gain...
    10 Sep 2009
    Nice)) Keeping an eye on this 1 lol)) Love the fan grill, was thinking about something like that 4 my case ))
  8. stonedsurd
    11 Mar 2009
    Where do you get that green tape? :naughty:
  9. jhanlon303
    7 Sep 2006
    I think Bill said somewhere in one of the logs or videos that it's low tack painter's tape. I use the blue tape because it doesn't leave much residue to clean when removed. I think the green is probably the same idea. Maybe an auto paint store?
    john
  10. stonedsurd
    11 Mar 2009
    Thanks John.
  11. mnpctech
    21 Apr 2003
    The best tape is 3M Scotch 233+ Green tape
    3M Scotch Green 233+ masking tape is used by Automotive Paint Professionals. It's highly conformable to curved surfaces on both metal and plastic. It has good adhesion in a large range of weather conditions. It will peel off without leaving any sticky residue. Most Auto Body Supply Stores should be stocking this tape. It's also readily available online. 3M Scotch 233+ tape has a premium price compared to other tapes, but it performs the best
    I also use the 233+ tape to mask off side panels sent to us for custom windows. It protects the surface from getting scratched by the Jigsaw. I've double layered the tape to insure some of hi-end aluminum case panels we customize are not damaged.
    One layer is fine for most steel cases with powder coated finishes like the Antec 300 pictured here.
    The popular alternative is 3M Blue "Painter's Tape"
    Blue Painter's Tape is a lighter material. It can start to peel off a surface if left on longer than 24 hours (depends upon enviroment)
    It doesn't adhere well in humid environments. It's intended primarily for indoor use, house paints in particular. Any other generic brand masking tape can leave adhesive residue. They can also lift paint when you peel it off if you had excessive overs pray on the tape.
    I know a lot of people can't afford to buy premium products like the 233+ tape, but we see this product as an investment in our quality of work. I would rather spend $12 for a roll of good tape than replace somebody's case panel because we scratched it.
    Hope this info helps you! :thumb:
    stonedsurd likes this.
  12. mnpctech
    21 Apr 2003
    Prep and applying primer coat to the Sniper exterior
  13. mnpctech
    21 Apr 2003
    These are the Urban Camo paint templates, cut from vinyl masking sheet on Roland plotter
  14. mnpctech
    21 Apr 2003
    White base coat applied!
  15. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    More more more! Urban cam is unpractical and that makes it cool :D
  16. stonedsurd
    11 Mar 2009
    Er, I thought the front fan grill wouldn't be painted?
  17. RuSGaMeR
    10 Sep 2009
    I've thought so too, but oh well ))) It's camo design, there's not much u can do)) plus we shall see what' it's gonna be looking like in the end))
  18. mnpctech
    21 Apr 2003
    It didn't look right leaving it bare aluminum. Urban Camo custom paint is finished on the Cooler Master SNIPER's side panels
  19. stonedsurd
    11 Mar 2009
    Awe-freaking-some! :D
  20. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    I want this case!! Man its amazing!!!:jawdrop::jawdrop::jawdrop:
