News The Wind-Powered Wi-Fi Repeater
Discussion in 'Article Discussion' started by CardJoe, 22 Jul 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. tozsam
    tozsam What's a Dremel?
    11 Jun 2010
    what about being built into a car design, the motion of the car would provide more than enough wind power. The amount of times I've been using my iphone satnav only to loose connection in the middle of nowhere, then when the connection finally comes back you hear the 'do a legal u-turn' and find out you have gone several miles in the wrong direction.
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    tozsam, that would be inefficient, you're in a car with a battery and an engine.
    What you need is just an antenna on the roof.
  4. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Just use a GPS based satnav tozsam, problem solved.
  5. scawp
    scawp What's a Dremel?
    8 Sep 2009
    Great stuff, might need a few of them but anything is better than WiMAX
  6. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    not a bad idea, the sooner we start moving off of fossil fuels the better for us in the long run.
  7. aoakley
    aoakley FriesWithStatic
    23 Feb 2010
    That's brilliant... so long as your value of "middle of nowhere" never exceeds "a third of mile from somewhere else that *has* got an Internet connection".
    Um..?
  8. WestHej
    WestHej What's a Dremel?
    3 Sep 2009
    Whats the latency like on this?
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    pretty cool but is only really useful in a field with a line of sight to the actual hot spot
  10. Gareth Halfacree
    4 Dec 2007
    They only *tested* it to .3 of a mile - standard Wi-Fi equipment with custom antennas has been known to reach multiple miles quite easily.
    Plus, it'd be easy to combine this with mesh networking technology like LocustWorld: that way it only has to be near another non-Internet-connected Wi-Fi mesh node, which in turn is near another, and so on - until you eventually reach the one node in the village which *does* have an Internet connection.
  11. -EVRE-
    -EVRE- What's a Dremel?
    12 May 2004
    Been doing this for years... but you would be surprised at how much power you need to generate for 100% up time and reliability. 200watt solar panel and 3kw of battery is needed to keep 4watts of radios running year round here in north Idaho.
  12. Anakha
    Anakha Minimodder
    6 Sep 2002
    Not really. If you need connectivity further out, you put several repeaters up, so the signal is carried along by the repeaters until it reaches your internet base station(s). It would, essentially, become a mesh network. It's how most rural internet access is provided. A company pays for a hard line to somewhere, then sets up a wireless mesh to cover the village.
Tags: Add Tags
