Case Mod - In Progress Theory | By Hannes ["What? Is this still on?" 22st.February.2014]
Discussion in 'Project Logs' started by Hannes, 29 Oct 2010.
  1. dogknees
    dogknees Minimodder
    27 Dec 2008
    Cool! A combination PC and Yoghurt Maker. Just what the world needs!
    :thumb::thumb::thumb:
    Nice mod Hannes. Great to see something that's not glowing green or blue. Despite my comment above, I really like the white coolant. It's a nice cool (As in temperature) look for coolant. :D
  2. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    lol, thank you! :thumb:
  3. peteski
    peteski long live the pc
    8 Jun 2011
    hi there hannes id just like to say grate job so far. and i realy like your sleeving i cant wait to get my new 100% modular psu (not sure what one) so i can do some first time sleeving :rock:
  4. Hannes
    24 Apr 2010
    Good luck mate! The composition is inspired (Stolen, ahem) from Xien16. An amazing PC-artist.
  5. Hannes
    24 Apr 2010
    Roboduck likes this.
  6. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    So awesome....
    +rep :thumb:
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    So nice, that coolant... How about painting or sandblasting the back side of that piece of acrylic covering the 5.25" rack, to make it match the colour of the coolant?
  8. Hannes
    24 Apr 2010
    :blush:
    I don't have access to a gentle enough blaster. The one I've used bent aluminum. But I'll probably paint it like thw floorpanel. :)
  9. Nutman
    21 Oct 2008
    Well, sanding it with grit 1500 could also achieve roughly the same result - OR, just paint the backside of it with thinned white spraypaint.
  10. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Awesome job man!
    This fluid looking great, and fits perfect on your build!
  11. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Just love milk and this whole build. Doing it in your one of a kind style.
    Looking very good Hannes. :thumb:
  12. Hannes
    24 Apr 2010
    As I did on the floor :thumb:
    peteski likes this.
  13. peteski
    8 Jun 2011
    looking sweet hannes
    +rep:rock:
  14. Hannes
    24 Apr 2010
    Thank you Peteski! :-D
    asura likes this.
  15. asura
    asura jack of all trades
    22 Apr 2009
    Frosting wheel for the acrylic? It's designed for soft metals (Ag, Au, Cu) so the one linked may be a bit aggressive, softer/finer/smaller wheels including 2.35mm shanked are also available.
    Is there any way to get a *horribly* tight bend radius from the link at the bottom of the reservoir? Through the acrylic sheet, horrible bend, back out the acrylic and to the GPU block in one piece of tubing... or would it look too much like a Nike "swish"?
    I keep wandering if you have something planed for the centre of your spread V8...
    Simply gorgeous by the way - I love the three tone sleeving.
  16. Hannes
    24 Apr 2010
    That may be a way to do it. It'll probably look cool frosted instead of painted. If I frost the plexi, I'll need to do the same thing to the floor.
    Actually, the link between the reservoar and GPU is only temporary. It will be Reservoar, pump, rad, GPU.
    I do not have anything planned, but maybe you have some food for thought. :)
    Thanks, man!
  17. Nutman
    21 Oct 2008
    Hm.... looking at the painted floor, I actually think the 5.25" rack-hiding plate would look better when painted. When frosted, you would still be able to see slightly through it, but the painted floor matches the "milk-filled" reservoir perfectly as it is right now - so, I vote for painting. ;)
  18. kelvinb
    kelvinb BF3 Username - D0rmarth
    20 Sep 2011
    Nice build,
    my suggestion on the build would be have you thought about mounting an LED in the side of your plexi as I think the effect would look great on this build.
    P.S - Please share some of your tips in how to get a clean looking build can never seem to get mine looking the way I would like
  19. Hannes
    24 Apr 2010
    I like that. Looks better with less work. :thumb: I'll match the paint-design, so the whole plate won't be painted. I'll do a similiar roof thing, as the floor. Or should I do it in an other material? Like Mesh or brushed aluminum?
  20. Hannes
    24 Apr 2010
    I'm going to have a Lian Li Ledstrip (damn thing cost like $30) mounted in an approximately 45 degree angle from under the floor panel. Illuminating the hardware. :)
    Well, I don't know.. Try to have a thought with everything you do, and you should have a slight case of OCD. ^^,
