Case Mod - In Progress Theory | By Hannes ["What? Is this still on?" 22st.February.2014]
Discussion in 'Project Logs' started by Hannes, 29 Oct 2010.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe: You have made that cooler turn from meh to woooah :D:rock::clap:.
  2. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    If that isn't recognision then I don't know what is! Thank you bro!:jawdrop:
  3. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    hhhhhh heaaartattaaack!!! my head nearly turned into cheesecake when I just SAW the king of cheesecake!!!
    :) hahahah
    EDIT: how will the fans work?
  4. Hannes
    24 Apr 2010
    What fans? :p I'm going to run it passively. :) It's for the looks
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    That is possibly the most amazing piece of modding I have ever seen, custom CNC water blocks are awesome in there own right but to modify an air cooler and change its appearance so drastically for the better is amazing!
  6. KidMod-Southpaw
    28 Sep 2010
    Passive sounds good! +1
  7. Hannes
    24 Apr 2010
    I can't believe the respons you're all giving me! I'm like :eyebrow::D:blush::rock::jawdrop::clap::eeek: and :worried: in the same time
    :thumb:
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    This is a must-subscribe-to worklog. Awesome photography, but anxious to see what parts will be water cooled and which that will not.
  9. Hannes
    24 Apr 2010
    :blush:
    I believe that I'll LC the motherboard, the RAM and maybe the GPU if I'm going to use the 5870. I'm thinking of using a lowprofile GPU and have it under the floor. I'll probably use EK blocks with plexi tops and white liquid, otherwise I'll paint the acetal tops white and use red or black liquid. :)
  10. KidMod-Southpaw
    28 Sep 2010
    May I ask how cool a 1055t will be passivley, a roof intake may help a little.
  11. Nutman
    21 Oct 2008
    Ok, thanks for the quick answer.
    Maybe Eddy from EK Waterblocks could make a white Delrin top for whatever block you'll be needing it for?
    Now, I might have missed your explanation somewhere, but can you explain why you don't plan in water cooling the CPU?
  12. Hannes
    24 Apr 2010
    I have no idea! :lol:
    They mass-manufacture their parts so he couldn't do that. The reason why I'll not lc the cpu is quite obvious isn't it? :p I have this viewtiful customized V8 to cool the CPU. :)
  13. KidMod-Southpaw
    28 Sep 2010
    If you haven't decided on your fluid colour yet; I hope you're using 2 loops, you could make one loop black or white fluid, and one red fluid.
  14. Hannes
    24 Apr 2010
    Hmm.. Well, maybe I'll do that. :) I have 2 sets of Laing D5 Vario and reservoars after all. I'll have a problem to fit two rads tho. ;-)
  15. KidMod-Southpaw
    28 Sep 2010
    External rad? With your skill a rad could look great outside the case? May I ask what's in the two loops?
  16. Hannes
    24 Apr 2010
    The two loops where your idea so you tell me. :p I don't have any blocks or rads yet - except all the bitspower products and the laing D5 vario pumps I don't have anything. :) I've listed the bitspower order in this thread I think.
    I'm not that fond of external rads so I don't think I'll use that solution.
  17. KidMod-Southpaw
    28 Sep 2010
    Sorry, I meant what will the loops be cooling? Graphics cards? The chipset on the crosshair 4?
  18. Hannes
    24 Apr 2010
    I answered that like 8 posts ago. :) MB, Ram and maybe GPU.
  19. nissanskyrice
    nissanskyrice Terminally Lazy
    10 Jul 2006
    I know its early days, but......... MOTY contender. That heatsink looks awesome.
  20. Hannes
    24 Apr 2010
    Aw, thank you! But it was way to easy to make to even be mentioned among those amazing builds.
