News Thermal analysts examine Xbox 360
Discussion in 'Article Discussion' started by CardJoe, 6 Aug 2007.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. completemadness
    completemadness What's a Dremel?
    11 May 2007
    Expert ? wtf ?
    The fan is small because they want to make the console small, if the console is only 60mm high, there is only room for a 60mm fan
    Larger fans shift more air at the same DB levels (and therefore, shift the same amount of air at lower DB levels)
    Also, if the gfx heatsink is such a problem, why the hell didn't MS use a slimline DVD drive, which would at least 1/2 the space required for it ....
  3. DougEdey
    5 Jul 2005
  4. Bl4ckM0onk3y
    Bl4ckM0onk3y in luv 2.0
    5 Aug 2007
    I checked the Videos on Youtube when some Japanese guys took the PS3 apart , and it was as shocking difference as Driving the Mercedes Benz Maybach and a Yugo, and i refer here that PS3 is the Mercedes ;F , the PS3 interior looks like it was build to last , while X360 was so messed up like i would see and poorly made DIY PC , the motherboard of X360 is only 5 or 6 layers thick , for such a hardware it should be at least 7 layer PCB. Also the solder points are poorly made , it simply looks like someone was running around inside with a hand solder. To simply put it i don't know a single person from my friends that had x360 and he didn't had to RMA it. Either the Dvd drive fails or the Ring of Death comes to play. Anyway i have seen some i486 based PC's back in my old days that had been better build then this plastic "toy" box.
  5. woodshop
    woodshop UnSeenly
    14 Oct 2003
    Yea.. thanks i'll remember that... feel sry for those in the Antarctic research station who wana play xbox after doing the whole polar bar club deal.
  6. Bl4ckM0onk3y
    5 Aug 2007
    but imagine an Xbox 360 as a life saving device, a person who felt into icy water on Antarctica , then he is wrapped in some blanket with xbox360' running, that way you can save 2 "lives" 1 is the one console suffering from Ring of death and the other is the person :naughty:
  7. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    damn the Graphics LSI can get over 100*C. thats insane. and the fact that nothing changed with the repair is quite ridiculous.
  8. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Seriously, how does a thermal expert arrive at the conclusion that small fans are ever quiet? Small fans have annoying high frequencies and need to spin faster to push the same amount of air as a larger one.
    Also, the 100 C thing isn't necessarily bad as long as it's built to withstand that temperature. I'm not sure if it is, I'm just saying it's okay as long as its within specs.
  9. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    My friend's 360 is seriously on it's last leg and we can't play it anymore without it freezing every 10 seconds and it doesn't matter what game we play it still does it. I would be so mad if I was my friend. He spent $499 on his Premium system in 2005 and for it to already be giving out and for him to now have to spend $100 and be w/o his system for a little over a month is just horrible. Not to be a fanboy (like everyone thinks I am, but am NOT) has the PS3 had any issues like this since its launch?
  10. Goty
    Goty Minimodder
    13 Dec 2005
    Only with the poorly ventilated demo kiosks. I run Folding@Home on my PS3 24/7 (well, when I'm not playing) and I have yet to have a problem.
  11. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    nope. even at currys, we have rammed it in a glass cabinet that is locked, and its on demo nearly 24/7. hasn't crashed once.
    i wish MS would improve the cooling. its easily done.
  12. Renoir
    Renoir What's a Dremel?
    19 Jul 2006
    As I understand it for a given rpm a smaller fan will be quieter in terms of db but the subjective nature of the noise is more objectionable (high pitched as you say). As you mention smaller fans need to spin faster to push a given amount of air but the key is how much air is required. If the components in the 360 were cool running enough then having small fans would be okay due to them not needing to spin too fast. Problem is the 360 components are not cool running.
    QFT. Take GPUs vs CPUs for example. The reference 8800 gtx cards tend to run fairly quiet whereas if a cpu were to consume as much power as the 8800gtx it would be diffucult to cool it quietly on air. The difference is the 8800gtx can get a lot hotter while still staying stable than current cpus and therefore doesn't require as much noisy airflow to keep withing specs.
    Just some thoughts...
  13. Bl4ckM0onk3y
    5 Aug 2007
    Well 90% of small fans need to spin faster then the large (lets say 92mm and 120mm) ones, if you look at the very VERY poor quality of components used in the xbox360 you will know that even does the ATI Xenos vga chip is designed to withstand the lets say "90-100C" then the solder points of the chip and the low layered PCB of the motherboard does not have to ;] , so you have it, low quality and excessive heat can lead to small failures that lead to global console crash (such as the dreaded Ring of Death )
    As far i read the PS3 had some minor issues with the Blue Ray drive , SONY states that failure rate is as high as 1% , people sometimes report random squared dots in games (probably bad shader unit in graphics chip) , also there might be some Hard Drive failures but they are presumed to be low since PS3 uses the Seagate Momentus portable drives (witch are reliable so far)
  14. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Touch Wood mine is ok apart from the random crash with certain games.
  15. Bungle
    Bungle Rainbow Warrior
    7 Jul 2007
    Was hoping to get an Xbox 360 at some point but the thermal issue keeps cropping up. Is there any noise from microsoft that they will address this problem in a future release?
  16. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    the Xbox is noisy full stop them fans are to noisy to start with
    if M$ say yes it was an fault with the Xbox thay will probably get sued allot (if not many USA peeps have already tyred to)
    dono why thay have not resoved this problem by makeing an new Xbox 360 that does not have these problems, Xbox 360 is the most unrelible console ever made and i not buy one untill its resoved with an revsion Bigger heat sink mite lower the temps an little bit
    but that Revew of an Xbox was an little lame due to the fact he did not bother to test the New Xbox 360 heat sink as well
  17. devdevil85
    29 Nov 2006
    /\ Why would they waste their time testing out the "new" 360 when "to [their] surprise, the composition of the repaired Xbox 360 looked completely the same as that of the Xbox 360 purchased in late 2005. It turned out that Microsoft provided repair without changing the Xbox 360's thermo design at least until May 2007."
  18. DougEdey
    5 Jul 2005
    The reports of the modified cooling didn't come till June/July anyway.
  19. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Hrm, bit-tech paraphrased the bit about the fan being made smaller to reduce noise ? the actual comment seems to be :
    Which would seem to make more sense coming from an expert.
  20. landi_uk
    landi_uk What's a Dremel?
    23 Mar 2002
    Well after my 360 being returned from repair for ring of death, it has a new second HS installed so MS are addressing this issue.
    It appears that this is only being done after June, so it would be interesting to see a re-evaluation of the article with the new HS, which is now being installed.
Tags: Add Tags
