Cooling Thermal compounds
Discussion in 'Hardware' started by The Razman, 12 Dec 2009.
  1. The Razman
    The Razman What's a Dremel?
    8 Dec 2009
    I haven't really found much to do with thermal compounds. I'm assuming they're a good idea though if I plan to overclock my system.
    Can anyone give me any recommendations for what I should be looking for in a thermal compound ... or tell me if I'm wasting my time, if I am? Looking to overclock my i5-750 on an MSI P55-CD53 (with a Titan Fenrir cooler) and want to make sure I have a solid cooling system in place.
  2. stonedsurd
    11 Mar 2009
    Arctic Cooling MX-2, Arctic Silver 5 spring to mind as excellent 'non-exotic' pastes.
  3. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    All I use now, tbh. Does wonders.
  4. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    Basically you can buy the Classical Thermal Grease like Zalman or coolermaster, if you want a better conductivity use the Artic Silver or Ocz Freeze , and for a bit higher the Ic Diamond 7.
    The only recommendation I can say is 'Dont Jeez your thermal paste over the CPU like a Kid with a Mustard Pot' it only need a tear nothing more.
  5. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    arctic cooling mx-3
  6. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    +1
  7. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    The only thing I can say is, stay clear of Coollaboratory Liquid Pro, awful awful stuff . . .
  8. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    IC Diamond 24 Carat. Saw a 5C decrease on IDLE vs AS5. And almost 10C decrease on Load (IBT) IC Diamond 24 Carat vs AS5. It also lowered my GPU temps by 6-7C on IDLE and 10-15 on load.
  9. DaTLiTe
    DaTLiTe What's a Dremel?
    26 Apr 2009
    wow that stuff aint cheap is it!
  10. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Ill agree with that, It works great but what a PITA. I used it once but now use AS5 its just so much easier to work with.
  11. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    In my personal experience I would say avoid the MX-3, found it impossible to work with, went back to AS5 and can't see myself ever changing again.
  12. smc8788
    smc8788 Multimodder
    23 Apr 2009
    What do you mean by 'work with'? All you have to do is put a small blob/line on the CPU and attach the heatsink, at which point it's only the temperatures that matter.
  13. Xonar
    2 Nov 2009
    I prefer to spread mine evenly over which ever surface I'm applying it to which requires a level of 'workability' in the paste.
  14. Teelzebub
    27 Nov 2009
    AS5 is one of the best just blob or a line in the middle and twist left then right and straighten and then tighten the cooler works best for me , Though I used the diamond one on the build in my sig I found that warming it up first was the best way with that one it's really thick , people tend to use too much TIM
  15. Validus
    Validus What's a Dremel?
    25 Aug 2009
    I like Ceramique, but AS5 is widely considered the best.
    And, as stated above, usually the problem is that people tend to use too much... You only want to barely coat the surface. Ideally you wouldn't want to use any at all and have perfect metal to metal heat transfers.
  16. sentek
    sentek What's a Dremel?
    5 Jul 2009
    im using AS5 atm,
    i would like to try the diamond stuff sometime though (or even better, make my own)
  17. TheBlackSwordsMan
    16 Aug 2009
    I use the diamond stuff, it look like grey Mud. After application with my after market Cooler, I noticed a few degrees of difference. But I dont think it is significative, for the price of 1.5g of Diamond compound you can get 3.5g of Artic S5 which is very good too. I take it because nobody use it loll
