Equipment Thermal Imaging - The Want is Strong
Discussion in 'Photography, Art & Design' started by Gareth Halfacree, 11 Jul 2019.
  1. Gareth Halfacree
    4 Dec 2007
    Biggest problem you're going to have there is the same problem I have: it ain't the choice of camera, but figuring out how best to deal with differing thermal emissivity and reflectivity across the multi-material surface of a PCB. Otherwise you'll have a pretty picture with absolutely no usable data behind it.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Yeah, we just use Flir camera for that. They're basically the best in the industry.
    I let the nice gentleman with the Phd deal with those problems :p One was is to use multiple cameras at different angles, that overcomes the reflectivity, but you need some fairly complicated software to map it out. Or structure you're enviroment to limit emmission sources, then you'll have less reflections.
    Arboreal likes this.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Ghetto solution: spray everything with grey primer. Or if you need to use it afterwards, dust liberally with talc (also good for structured light scanning, meatbags tend to complain if you want to paint them grey). Doesn't play as nicely with the IR + vis composite trick unless you do your visible light photo first and manually realign for the composite afterwards.
  4. Bloody_Pete
    11 Aug 2008
    Depends on what its made from, some will be nearly transprent and others highly reflective.
  5. Gareth Halfacree
    4 Dec 2007
    I've found a midpoint between "paint it" and "dust it": Crack Detector Developer. It's basically a slurry of zinc oxide in naphtha. Spray it on, the naphtha evaporates, leaves a coating of zinc oxide behind - and you can wash the zinc oxide off afterwards with isoprop and a bit of elbow grease. You never quite get it out of *every* nook and cranny, but it's good enough!
    Bloody_Pete, edzieba and Arboreal like this.
  6. edzieba
    14 Jan 2009
    Ooh, that sounds like a good alternative to zinc-rich 'weld through' primer!
  7. Gareth Halfacree
    4 Dec 2007
    That was quick:
    Postage is saying 1-8 weeks, mind, so it could still be a while before it's in my sweaty mitts.
  8. Bloody_Pete
    11 Aug 2008
    What are you making? I use PCBway is they so cheap its ridiculous!
  9. Gareth Halfacree
    4 Dec 2007
    edzieba and Bloody_Pete like this.
  10. Bloody_Pete
    11 Aug 2008
    Oh awesome,I'll have to keep them in mind!
  11. Gareth Halfacree
    4 Dec 2007
    3D doodad shipped - let's hope the delivery is closer to the one-week estimate than the eight-week estimate!
  12. Gareth Halfacree
    4 Dec 2007
    Doodad get!
    Going to pull out the camera and give it a whirl now. Fingers crossed I don't end up accidentally unscrewing the whole lens assembly!
    EDIT:
    It's a little fiddly - has a tendency to pop out of the lens assembly, and adjustment is pretty stiff (presumably deliberately so, given it's not actually supposed to be adjustable outside a factory setting) - but it definitely works.
    Remember this?
    Well, that now looks something like this:
    Bit of an improvement, I'd say!
    (It's a slightly unfair comparison, 'cos I've washed the gunk off the Pi Zero since the first picture. The metal bits are false detail from reflection and different emissivity, but you can see from the mounting holes and the GPIO pins that there's also a real difference in clarity.)
    Cheers, @edzieba - now I just need to work out why it's started having trouble with its USB connection since last time it was out of the box...
  13. Gareth Halfacree
    4 Dec 2007
    A quick test of blending with a visible-light image:
    Needed a bit of fiddling 'cos it's quite sensitive to different heights, and the finished result is very quick and dirty - it's the default iron palette rather than my preferred high-contrast rainbow and the board under the camera was, again, not treated, plus I didn't remove the shadow from the bottom of the board - but it proves the concept: I can indeed use the thing instead of the C2 for overview stuff.
    It's still struggling a bit with USB connectivity, for some reason - keeps disconnecting and reconnecting itself. I'm sure it wasn't doing that last time I was using it. That's unrelated to the lens-focusing games, mind you!
    Arboreal, MLyons, David and 1 other person like this.
  14. Bloody_Pete
    11 Aug 2008
    Windows or Linux? We've had loads of problems with linux drivers for Flir stuff over the years!
  15. Gareth Halfacree
    4 Dec 2007
    Linux, but without any drivers installed (well, without any third-party drivers: both the cameras I've got just expose themselves as a USB Mass Storage Device and a V4L-compatible webcam.)
    Bloody_Pete likes this.
  16. Arboreal
    21 Jan 2011
    Thanks for the update GH, I was wondering yesterday how you'd got on with the mod.
    Interesting stuff, good result too!
    MLyons and Gareth Halfacree like this.
  17. Gareth Halfacree
    4 Dec 2007
    I'm actually writing this up now, so I needed better comparison shots - which means getting out the crack detector and spray-painting a Pi.
    Before doodad:
    After doodad:
    Ta-da!
    EDIT: Oh, and whatever was up with the USB connection seems to have resolved itself, 'cos it's staying connected nicely now.
  18. Bloody_Pete
    11 Aug 2008
    I love thermal images, I keep forgetting to grab my works one so I can investigate my PC with it!
  19. Gareth Halfacree
    4 Dec 2007
    After doodad *and* post-processing. Purty!
  20. Gareth Halfacree
    4 Dec 2007
    Oh, and by way of comparison here's a similar shot - different scale, though - taken on the FLIR C2.
    You can really see the extra resolution on the ETS320: there are individual header holes instead of a single grouped lump, the outer edge hugs a lot more closely especially where the ports and microSD are, the mounting holes are more detailed...
    That's what going from 80x60 to 320x240 does for you!
