Cooling Thermal pad in H80i any good or should I replace?
Discussion in 'Hardware' started by dinoscothern, 18 Aug 2013.
  1. dinoscothern
    dinoscothern Minimodder
    16 Aug 2010
    Looks like there is a thermal pad on the copper plate in my new H80i.
    Back in the day (when I was a lad) these things were thought rubbish and stuff like Artic Silver was the stuff of choice.
    Should I remove the pad and use a normal 'thermal' compound like AS, or should it be fine?
  2. Uxon
    Uxon Minimodder
    14 Dec 2010
    Err, didn't think the corsair all in one coolers used pads but I might be wrong, used to be they pre-applied some paste which was pretty reasonable paste but if you prefer to use your own thermal compound it will probably be a couple of degrees C cooler.
  3. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    My H80i came with paste applied. I would put some decent paste on.
  4. dinoscothern
    16 Aug 2010
    Mmm maybe it was paste, but looked like a pad, well too late now.
  5. Teelzebub
    27 Nov 2009
    Definitely doesn't come with a pad, I remember reading it would come with shin-etsu paste on it which is one of the best paste.
  6. dinoscothern
    16 Aug 2010
    What is the preferered thermal paste these days?
  7. RedFlames
    23 Apr 2009
    provided you avoid the really cheap ****, the difference between most types thermal goo is negligible...
  8. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    It's not a thermal pad it's a square of thermal compound that looks to be screen printed on or something.
    Either way the stuff on my H100 has proven to be perfectly adequate.
  9. heir flick
    heir flick Minimodder
    2 Feb 2007
    I have the h80i and the paste on works fine
  10. docodine
    docodine killed a guy once
    10 Feb 2007
    dow corning, not shin-etsu
    either way the stuff that comes with the h80i is as good as, if not better than the majority of after-market goop
