Cooling Thermal Paste?
Discussion in 'Hardware' started by matt_lumley, 22 Sep 2011.
  1. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Hey guys,
    just a quickie really, is the thermal paste that comes with the Be Quiet Dark Rock Pro suitable for overclocking an i5-2500k?
    If not what would you suggest?
    Thank you in advance for advice and answers i know i will get!
  2. David
    7 Apr 2009
    I don't have a Dark Rock Pro, but I'd imagine it'll be just fine.
  3. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    I'm sure it would work fine, however if you plan on running it full tilt for any length of time, and notice the temps are too high (over 72.6 from memory) then Id suggest getting some Isopropyl Alcohol and cleaning it off and replacing with a thin line of Arctic Silver 5 or similar. It can drop 5 degrees off without too much hassle.
  4. rv88uk
    rv88uk What's a Dremel?
    28 May 2011
    The dark rock pro comes with Shin-Etsu X-23-7762 which is pretty decent (insanely hard to spread though), I'm using it on mine and I get good temps. If you want to try an alternative I've never seen a better resource that this, the 2011 roundup is slowly being finished and covers pretty much all the main contenders. Arctic Silver 5 isn't the best paste nowadays, but I still use it every now and again as it's very easy to spread.
  5. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Im old school :)
  6. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    hehe yeah try the newer stuff.. I liked as5 a couple years back- but it takes too long to cure.. better ones out there with no cure time
  7. matt_lumley
    28 Apr 2010
    could someone recommend/ link me to a good but not massively expensive one i can buy with my CPU order at the end of the month?
    Much love!
  8. thehippoz
    19 Dec 2008
    use artic cooling mx-4 nowdays.. it supposed to last 8 years
    thermalright chill factor is pretty good stuff too.. least the newer batches- just used up the last of it on a playstation reflow
    mx-4 is kind of expensive- the downside
  9. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Then use mx-2 :D Still works like a dream.
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I use AS5 for CPU's and Ceremique for GPU's, but the temp differences between all of the major names are only a couple of degrees really.
  11. rv88uk
    28 May 2011
    To be honest getting the application right (thin even layer) probably matters more than the paste you choose, a couple of degrees here and there shouldn't make a massive difference. The only thing I've seen that is in another league entirely is the Indigo xtreme stuff, but it's pretty expensive and looks kind of scary to apply.
  12. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    ........ wow, indigo Xtreme is ridiculous. I would get some of that stuff if my cpu ran at anything higher than the 30degrees it currently sits at. ;)
  13. adamix
    adamix What's a Dremel?
    21 Sep 2011
    Agree with rv88uk, a proper application can mean a bigger difference than the choice of paste. Currently I use Arctic Silver MX-3, very good, non-conductive and easy to apply. Cheap too (if you know where to look).
  14. Skeese
    Skeese What's a Dremel?
    2 Sep 2011
    Stock TIM would be fine but if you want to buy I'd suggest MX-3 or AS5 :)
