Hardware Thermalright Archon SB-E X2 Review
Discussion in 'Article Discussion' started by Meanmotion, 3 Apr 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Shirty
    18 Apr 1982
    What a brilliant performance... but it's MASSIVE!
    For those who don't need the few degrees Celsius premium I'd still recommend a Corsair Hydro at a similar price point.
  3. Jipa
    5 Feb 2004
    Thermalright cooler reviews are boring, because the name alone says it all. They just don't produce crap, do they?
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Is it me or is the cooler VERY close to the back of the GPU in your photo of the 2011 rig?
    Any GPU's with backplates will clash won't they?
  5. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Great review and a great performance, but why does it have to be such an awful colour? Why can't they at least offer plain black fans if they don't want to get in to the various colour ranges?
    Even without a case with a window it would bug the hell out of me knowing that was in there.
  6. Xir
    Xir Modder
    26 Apr 2006
    Impressive, so aircooling isn't as dead as often said :clap:
    Shame the Macho isn't in the testing list, would have been nice to see it compared to this one
    Anyway, a question:
    Threy're all thumbscrews, what wrench?
  7. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    Excuse me if I'm wrong but I think Matthew was referring to Thermalright's Pressure Vault Bracket System:
  8. jrs77
    jrs77 Modder
    17 Feb 2006
    After having tested some AIO watercoolers I'm aswell back to good old aircooling, as a good aircooler is allmost as good and in most cases more silent actually.
    Other badass-aircoolers that can compete with a Corsair H100 are the Phanteks PH-TC14PE or the Silverstone Heligon HE01 for example.
  9. SchizoFrog
    5 May 2009
    Speaking of which, why wasn't the Phanteks PH-TC14PE in the test when it is mentioned in the conclusion? I know you can't compare every cooler but it does offer better performance while offering the colour options as mentioned. If you needed to cut down the table surely we do not need to see all 3 settings for the water coolers.
  10. thom804
    thom804 Minimodder
    22 Oct 2009
    Bleh, not enough of a difference to make me change out my Tranquillo. I'll keep saving for a Kraken then I guess.
  11. blackworx
    blackworx Cable Wrangler
    31 Jan 2008
    Consistently outstanding design and build quality.
  12. enciem
    enciem Minimodder
    23 Sep 2009
    I reckon horrible coloured fans have been adopted as a mark of quality in the cooler market. The fan colours and the clips they're using here look a lot like the Noctua coolers I had
  13. Xir
    Xir Modder
    26 Apr 2006
    Yup, which has a thumbscrew right smack in the middle of it, firdt page, last picture. ;)
    AHa, the central pressure thingy is a thumbscrew, but the plate holding it has bolts.
  14. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Seriously? It's been a little while since I've needed to get into my case, and I couldn't even tell you what color fans I have in there at all, HSF or case fans.
    I'm not arguing your main point, though - they are pretty heinous. Slightly better than than the weird fleshy tones of Noctua fans, but not much.
  15. Kasius
    Kasius Bringin' the dremolition
    16 May 2003
    Even with its vast enormity it still looks smaller than my Frio, might be time to trade the ole' dog out.
  16. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    Ah, thought it might be too obvious. So the plate holding the new Pressure System down is what BT were on about re: the wrench - mystery solved :)
  17. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Still using my IFX-14 with 2 x TY140 fans running at minimum speed. Keeps my Q9650 in the low 50's while running BF3. If I had to replace it it would be with another Thermalright product.
  18. TheDarkSide
    TheDarkSide What's a Dremel?
    22 Feb 2011
    i have a silver arrow, so does this one slot above it or below it in terms of performance? can't really tell.
    Anyway thermalright do indeed make quality producs, but i'm going to echo others in that i don't understand why they can't just make black fans? i actually replaced the TY on my cooler with corsair SP fans just because of that.
  19. MeddlE
    23 May 2011
    I pick my products based on performance and not on aesthetics.
  20. WALKYRIE
    WALKYRIE What's a Dremel?
    29 Aug 2012
    I agree, another awful beige fan
Tags: Add Tags
