News ThermalRight demos heatsink chassis
Discussion in 'Article Discussion' started by Tim S, 6 Jun 2007.
  1. jjsyht
    jjsyht Hello, my name is yuri
    19 Jun 2004
    I know ThermalRight for their good thermal conductivity.
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i was rather pissed off when i saw that, as i had just finished designs for a similar idea for my HTPC i was planing on surprising you guys with this summer hoilday.
    'Hangs head walks slowly back to the drawing board swearing and thinking!' :wallbash:
  3. tk421
    tk421 Idiot.
    15 Jan 2002
    forget the 120's kids - put one of those coolermaster squirrelcage fans from the original stackers in there.
    or one of those monster 250mm slow fans. on the top - drawing air out.
  4. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    I wonder how're they planning to deal with cpu sockets in different locations on different motherboards. If it only supports certain motherboards that'd be kind of pointless. I like the look of the full tower though (go back and get more pictures please :thumb: ).
  5. FooTemps
    FooTemps What's a Dremel?
    31 Aug 2004
    Well that design is a bit overboard... I figured a heatsink taking up a single side panel would be better than taking up four sides of the case.
  6. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    that does seem to be a fairly glaring flaw... and any removable modules for different boards type system will just kill the ability to transfer the heat....
  7. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    As others said, the flaws on this case outweight the good. Dust, Cuts, Damage, Weight, and high risk of spills.
    if they put like a light over lay of metal around it to protect it, that would be better.
  8. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    or some acrylics :dremel:
  9. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    wow okay Im sorry but that is simply cool, may not be to practical but hey Ill take one
  10. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    you could mount the motherboard on an adjustable tray so it always lines up with the heatsink... this case is so far out and cool I just have to have one. I wonder how much they will cost. I'm guessing alot but it may be worth it.. although the jokes about compensating will be excruciating :p
  11. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    I can't see that being put into production, a combination of dust, fragility, expense and lack of adaptability to different component setups and locations. I wouldn't even use one myself if it were free, it'd be too much hassle to look after!
  12. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Cost! A ThermalRight heatsink costs 100NZD and that is minuscule compared to this.
  13. otispunkmeyer
    otispunkmeyer What's a Dremel?
    4 Mar 2005
    i dont know about too much, perhaps its not too much, just unecessary surface area. though there is alot of metal to conduct heat into, great so long as you can get rid of it via convection or something.
    thing is, for cooling a fin, its best to have a turbulent flow of air over it. if its a laminar flow it cooling effect is reduced, but long fins are best.... if the flow rate is right it'll have more chance of becoming turbulent at some point along the fin.
    i have the calculations some where.
  14. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Holy crap, that thing is ginormous! Performance charts?
  15. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    I have a cat and he would definetly brake that case in like 2 minutes of me getting it home :D also how could you mod it, there is nothing to mod on it :wallbash: it has a front and a back to it and nothing else :wallbash:
  16. tk421
    tk421 Idiot.
    15 Jan 2002
    well all of you guys talking of cuts and fragility and dust - go have a peek at thermalrights website.
    apparently, there are outer panels - the gifreakingnormous heatsink is actually on the inside of the case.
  17. MrHydes
    MrHydes What's a Dremel?
    24 Mar 2008
    how is this supose to work?
  18. HourBeforeDawn
    26 Oct 2006
    Well considering this was at last years Computex, I never saw this come to the market so I guess it didnt work to well.
Tags: Add Tags
