Cooling Thermalright HR-05-SLI NB sink
Discussion in 'Hardware' started by jopers1986, 12 Feb 2007.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    It does look like you could, but it also seems that you would have to remove your motherboard to remove the stock NB Heatsink as it looks like it uses push pins that you have to pinch the barbs on the back to get them out.
  3. jopers1986
    7 Jan 2005
    yeah, was thinkin about taking a pair of wire snips to the pins on the current sink...
    lol
  4. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Just get it and find out, I can't seem to find a review or anything on google that will tell me. Was going to get this myself. But then I got a waterblock instead.
  5. jopers1986
    7 Jan 2005
    yeah think i'll just risk it... i would get a waterblock, but my watercooling days are over! nasty leaks cost me money :( think i'll just risk it, it's not to much effort to take the mobo out i guess, and will be worth it to shut that pi**in NB fan up :) thanks
  6. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Yeah, when i build my next loop I will be using FluidXP Leaks don't cost money (unless its a big one)
    You could always cut a hole in the back of the mobo tray so you don't have to remove it, you know, go to excessive trouble just so you don't have to do something quite a bit simpler.
  7. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
  8. jopers1986
    7 Jan 2005
    yeah i had a big one.... cost me my mobo, and gfx :( ooops
    hehe yeah thinkin about cutting a hole in the back tbh, looks pretty sweet if you do it right then do a back window! just need to be careful with the old dremel aye :D
    ii'm using this on the lanparty rdx-200, you think i could have got away with using the normal (NOT sli version) one?
  9. Guest-23315
    Guest-23315 Guest
    nice to see you back around ere' Jopers
    those coolers are supposed to be the muts.
  10. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I think you may be able to get away with it. The Northbridge on that looks quite well placed to not be in the way of the card/s.
    EDIT: With dual slot coolers it might come a bit close though. Might have to look at the dimension diagram before getting it.
  11. jopers1986
    7 Jan 2005
    ah cheers!!! didn't no i was being missed... havn't really been doing much wtih my pc recently to busy with uni work!
    just lookin at the pc now and don't think i'd get away wtih the normal one, the headsink is in the way! lookin forward to it comming!
    and what does "mut" mean? lol
  12. jopers1986
    7 Jan 2005
    it came today and now have it in! is pretty smart! looks ace, i'll wack some pics up later!
    now the loudest thing in the pc is the new HDD... :eyebrow: not impressed! dont get samsung HDDs! i miss my WDs!
