Hi The Thermalright LGA775 Bolt-Thru-Kit Converts Ultra-90 and HR-01 for use on 775 Motherboards, does anyone know if this is compatible with the Thermalright Ultra-120A
http://www.heatsinkfactory.com/thermalright-lga775-bolt-thru-kit-p-16470.html "Designed for Ultra-90, Ultra-120, and HR-01 only." http://www.heatsinkfactory.com/thermalright-true-black-120-rev-a-cpu-cooler.html "Plus the TRUE Black 120 Rev.A is now compatible with Intel's Socket 775, 1366 and AMD's Socket AM2 right out of the box - no accessories or adaptors needed." It appears that the Ultra 120 Rev. A installs just like the original. I would say it should work fine.
Well I recently fit the kit to a AC Freezer 7 Pro, so I would imagine it'll work fine with just about any 775 based cooler.
Believe me it was so worth it, my temperatures over halved after I fitted it. I'm currently running my Q6600 on 3.2Ghz with a temp of 36 degrees and the fan only running at 1200 RPM!
I will be soon, gotta get college out of the way for this year first (just a couple weeks now), then ill be going for at least 3.4 probably 3.6
Just had confirmation from Thermalright that the Thermalright LGA775 Bolt-Thru-Kit is compatible with the Thermalright Ultra-120A
