Does any1 know any sites that currently have this in stock? The ones i've looked at or all out of stock or 2-3 weeks and this is the one i'm after. I don't know of any better h\s so i'm sticking with this decision Thanx Death
If nobody has them then you'll have to wait. There's probably only one or two main suppliers in the UK. I'd shoot an email or two off to get a set date when they'll be available.
you might want to consider the slk-900a, i know it doesn't have the heat pipes but its 10 bucks cheaper at frozencpu.com and its in stock. I have a slk-900a and an sp-97 and there is only about a 1-2 degree difference.
Yeah but shipping from New York to the UK would be both slow and expensive. It would probably make up price by quite a bit and about the restocking time.
They have every other one in stock apart from the SP-97, they have the SP-94 in stock, i can't see the difference between the two on pics, and on a few sites they say it fits socket a??? what is the actual difference? Death
i just bought a sp-94 for my p4 machine and yes it can fit some athlon boards because it has 2 sets of mounting holes in the base. so if your mobo has mounting holes for the hsf it should work just fine.
Yea But whats the difference in terms of cooling? shape\size etc...?? Or is it just the mounting holes are slightly different?? Death
XP-120: http://www.sidewindercomputers.com/thxpforinp4.html Make sure its compatible with your motherboard, or else just send them an email asking
LoL LoL so may people are reccomending that h\s lately, how is it compared to the SP-97? anybody? Death
the only difference i can find between the 94 and 97 is the mounting base, i will double check and let you know.
Just the mounts afaik. Mail the supplier you intend to purchase from And ask about the neo backplate.
Fan What would be the best fan to include with the SP-97 as i can't find any 92mm Deltas Unless someone can point me to some Death
Yeah they blow alright - I had one on my sp-94 but it was just way WAY too noisy and I binned it in favour of a 92mm zalman, much better. The drop in temp that the delta fan gave was only a couple of degrees - not worth the noise IMHO.
I noticed no difference between an 80mm delta sceramer, and a 92mm vantec stealth. and about a 3' drop using the 92mm tornado. No results from my blower yet, will let you know though when i do.
