Cooling thermalright true copper cooler
Discussion in 'Hardware' started by bobtheangryflower, 5 Jun 2009.
  1. bobtheangryflower
    bobtheangryflower lalala
    29 Oct 2007
  2. Slaymate
    Slaymate bit-tech Slayer
    15 Feb 2009
  3. bobtheangryflower
    29 Oct 2007
    thanks
    wow now i want a better gpu cooler too after seeing ur build
    and with fans i figure if its worth doing its worth overdoing lol
    besides i dont care about how loud it is i always have music on and ceiling fan on high
    plus an xbox 360
  4. wyx087
    15 Aug 2007
    the copper version have about 2kg of weight........ while the normal one is only 800g.
    unless you've got something else holding the thing up, i'd worry about the weight of the thing in a tower PC.
  5. Pookeyhead
    30 Jan 2004
    According to various tests I've seen, the difference between the copper and normal versions are minimal also.
    That weight however... is a concern for me.
  6. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    I agree with Pookeyhead, there is almost certainly no difference. After all, heatpipes are something like sixty times more efficient than pure copper.
  7. bobtheangryflower
    29 Oct 2007
    well im kinda thinking of getting it for the looks now too
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Get a TRUE Black for looks!
  9. wyx087
    15 Aug 2007
    agree, Black looks fantastic, my housemate just ordered a Black, i so want to change mine to black.
    (i've got the very original TRUE back when it had just been released)
  10. bobtheangryflower
    29 Oct 2007
    i like copper but if i decide to go with anything else it will be the black
  11. The.End
    The.End What's a Dremel?
    27 Apr 2009
    If you have a tower then don't get the copper, its going to put a strain on the motherboard and moving it around is not a good idea, plus it's has the worst cooling to $ ratio of any cooler by a very long margin.
  12. bobtheangryflower
    29 Oct 2007
    i can always lay my tower on its side and itll still work just fine
    but ya it is expensive
    its either this or a zalman reserator not sure if i wanna go risk watercooling
  13. Joekerh
    Joekerh Penniless enthusiast
    1 Mar 2009
    The original TRUE is nickel plated copper. Heatsink copper is plated to prevent oxidization. To see a performance boost but not break the bank... get an original TRUE and lap the base to reveal the copper for better heat transfer.
  14. bobtheangryflower
    29 Oct 2007
    i might do that thanks
  15. Frohicky1
    16 Apr 2009
    Alas, copper tarnishes over time too so full copper TRUE would lose its shine :(
  16. Slizza
    Slizza beautiful to demons
    23 Apr 2009
  17. Slaymate
    15 Feb 2009
    Thanks :D
    The True Copper is heavy, but I move my PC around quite a bit and I've had no problems. I've even loaded it up in the car a few times for a little traveling with no problems. Just don't drop your PC.
    And Copper dissipates heat better than Aluminum, so while the True and True Black are quite simular, they are still a step behind the Copper. As for the price, I can't argue with that. It is expensive and it offers the worst price to performance ratio. But if you want the best air cooler you have to pay for it :D
  18. Ady6UK
    Ady6UK Feck Off
    24 Apr 2009
    I must start by saying Slaymate, I'm not disagreeing with what you've said but just adding to it. Copper does transfers heat faster than aluminum but to those that don't know, aluminum still dissipates the heat faster to the surrounding air. I'd have say the excellent Thermalright's design obviously adds to its performance as your results (and others in general) have shown.:thumb:
  19. Slaymate
    15 Feb 2009
    Aluminum dissipates what heat it picks up faster. But copper absorbs more of the heat faster, so while it may dissipate that heat slightly slower it's still dissipating more heat faster.
    But with what were dealing with the difference is only a few degrees at best. It all comes down to how hard your hunting the mighty Megahertz.
  20. bobtheangryflower
    29 Oct 2007
    im hunting the Megahertz to extinction lol
    and with the tarnishing i plan on regularly soaking it
