Hardware Thermaltake Core G3 Review
Discussion in 'Article Discussion' started by Dogbert666, 8 Sep 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Interesting.
    Odd as it may sound, laid on its side it would make an ideal, albeit oversized, HTPC case, those measurements would allow it to slot nicely on one of my TV stands shelves, the front of the case is aesthetically neutral as well, giving no real clue that it's meant to stand vertical.
    The space and cooling environment would be far better than one of the smaller cases that you'd normally consider, I'd imagine a nice meaty overclock on the CPU & GPU would be perfectly possible, which isn't the case in some of the smaller solutions.
    ..Or is that the whole point of this case.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    I'd like to see more manufacturers taking the SFX plunge with their cases tbh. With SFX PSUs getting ever more capacious there are fewer and fewer reasons not to use them even for larger builds. Would be cool to see what manufacturers could do with the space that they free up.
  4. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    Is it my imagination or are the photos very bright or washed-out looking?
Tags: Add Tags
