Thermaltake Ducting Mod
Discussion in 'Article Discussion' started by Jamie, 18 Sep 2003.
  1. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Thanks to Tau for this review.
    Any question or comments?
  2. Risky
    Risky Modder
    10 Sep 2001
  3. m2c4u
    m2c4u What's a Dremel?
    11 Nov 2001
    Hmmm, isnt the fan pointing away from the duct? So its acutally sucking out through this. In the diagram its showing it blowing air through the heatsink so maybe a alpha pal wasnt the best heatsink to use as most of use use conventional "blowing" heatsinks. Just hope it works as well as it does sucking or even possibly better pushing.
  4. Tau
    Tau Sharingan!
    17 Nov 2002
    I don't see why it would make much difference if it were sucking or blowing. Its just a piece of tubing, its irrelevent which direction the air travels through it.
    But then maybe I'm wrong....
  5. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    This might be a silly question but...if you had 2 TDM's would they make a 90 degree tube? It looks that way but I wanted to make sure..
  6. cderalow
    cderalow bondage master!
    23 Jan 2002
    for the heatsink he's using, the orientation is correct
    the heatsink (One of the Alpha PAL series) is supposed to have the air drawn through it instead of blown onto it for optimal use (which is partly why they work so well... its pulling air through so you tend to lose the large dead spot from the hub)
    granted, the performance change between sucking and blowing is only a few degrees...
  7. Tau
    Tau Sharingan!
    17 Nov 2002
    No, It won't make 90 degrees. But it'd be pretty close
  8. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Thank you sir :thumb:
  9. Mat-d-Rat
    Mat-d-Rat Drive it to the edge baby
    30 Aug 2001
    I can see how it would help with the centre dead spot, but as the fan is in effect blowing at an angle, won't all the air be forced to the top point of the bend? I mean the air is still being sent straight, it can't bend!! I think your better off getting a 80>60 mm adapter!
  10. aCe2k
    aCe2k What's a Dremel?
    1 Jan 2002
    My guess is that an 80>60 adapter would do the same job, but the fact that the Alpha needs an 80x80 fan mounted you would need an 120>80 .. and that again will resault in a more airflow and more noice.. :D Wouldn't it ?? :confused:
  11. aCe2k
    1 Jan 2002
    Anyway, if i only could find a reseller that hva it in stock :sigh:
  12. aCe2k
    1 Jan 2002
    Got reply from the guy's over at Fleetwood Comp.
    Dont those guys wanne earn money ?? i'm just asking :rolleyes: :p
  13. Tau
    Tau Sharingan!
    17 Nov 2002
    Surely the air would follow the curve of the pipe? I mean, thats the point of making things aerodynamic. If the duct had an abrubt 90 degree bend (Think the side of a box), then it would hit the edge causing turbulence and would probably negate any improvement you had achieved by removing the 'dead spot'. However, being a gradual curve, I don't see this as being too much of a problem
  14. Risky
    Risky Modder
    10 Sep 2001
  15. Mat-d-Rat
    30 Aug 2001
    What I mean is...
    But that's just my thoughts, at least more cold air is hitting the middle I suppose.
  16. pranks7er
    pranks7er mange tout
    25 Dec 2002
    i would look good illuminated
  17. Tau
    Tau Sharingan!
    17 Nov 2002
    Well, I'm not sure how good you would look illuminated, but the duct looks pretty nice :D
  18. U U U
    U U U What's a Dremel?
    27 Jun 2002
    like this you mean
  19. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    is it blowing or sucking, if it is sucking no dead spot, sort of like there isnt a dead spot in a garden hose when it has water flowing through it. Blowing, I would think maybe at the very start, but the airflow isnt a cylinder its more cone like so I think the whole heatsink would get air, just more to the opposite side.
  20. Guest-16
    Guest-16 Guest
    that just wouldnt happen. It would create static pressure that wouldnt be directional that's all. Youd loose some flow obviously because its further away but youve assumed air doesnt bounce off the sides of it.
Tags: Add Tags
