Hardware Thermaltake Frio Advanced Review
Discussion in 'Article Discussion' started by arcticstoat, 19 Dec 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Ratchet219
    Ratchet219 What's a Dremel?
    9 Aug 2011
    Disappointment....
  3. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    thermaltakey
  4. towelie
    towelie How do I Internet!!
    1 Sep 2011
    Interesting results on the 2011 socket between the Thermal take and the H80 in comparison to the other sockets.
  5. tseax
    tseax < >
    5 Mar 2009
    I'd consider a Noctua HSF instead, with their own (Focus Flow 120mm NF-F12 PWM) engineered quiet fans.
  6. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    I've got the original Frio and haven't seen any reason as yet to upgrade it, its basically excellent.
  7. slothy89
    slothy89 MicroModder
    17 Feb 2011
    Wonder how those fans go on a water cooling rad? Being thicker and with flat walls around the fan you'd expect the static pressure to be better.
    Interesting to see If these fans make it to individual sale
  8. Dedlite
    Dedlite What's a Dremel?
    4 Apr 2010
    I've got an original Frio, running my i5-2500k at 4.3ghz, with *1* fan at 70% speed. Considering I could easily hit 5ghz (but probably sounding like a jumbo jet on take off!) I see little point in 'upgrading'.
  9. Janek566
    Janek566 What's a Dremel?
    21 Apr 2011
    I ordered it 2 days before this review on bit-tech xD I bought it since it apparently has and edge in terms of 2-3 degress C (compared to frio). I do not care about the noise and I have a strange feeling that the noise it produces is exaggerated by websites like this. Still, after I'm done building my system I will pop back and comment on how the cooler is doing. I seriously think it won't be that bad.
  10. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    lol why is there no temp comparison to the original frio so we can see what the difference is or if its worthwild to get over the original?
  11. ssj12
    ssj12 Minimodder
    12 Sep 2007
    That's what I'd like to know. I'm starting to question this site's reviews because they are starting to miss important factors like comparisons to older versions of a product.
  12. zyklon
    zyklon What's a Dremel?
    24 Dec 2011
    The "pull" exhuast fan is the noise maker because of the profile of the fan blade. If both the push and pull fans are set as CPU fan, then they will spin at the full 1900++ rpm under load, which will make a really loud whining noise.
    If the pull fan is set as a system fan and controlled to around 1000rpm, while the front "push" fan is connected as cpu fan and controlled by the mb, then it will be much much quieter. Reducing the speed of the "pull" fan doesn't seem to affect the temperature significantly, at least not on mine.
    Also, in one of the photos in the first page of the review, you seem to have got the front and rear fan swapped.
Tags: Add Tags
