Hardware Thermaltake Frio CPU Cooler Review
Discussion in 'Article Discussion' started by Claave, 14 Jul 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Considering how many people use RAM featuring tall heatsinks in an air cooled system I can't help but think that these latest and greatest heatsinks that interfere with the RAM have a major oversight, and should be scored down accordingly. Surely the scores should reflect just how many people are not going to be able to use this heatsink?
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    Did you take any pics of the Frio installed inside a case, or at least on a test bench or something?
    I'm surprised that this didn't make it on this month's Gaming Workhorse, given the $10 difference between it and the Fenrir..
  4. SchizoFrog
    5 May 2009
    I think that they wanted to show a couple of options rather than just use the same componant on all systems as the FRIO was used in the 'Premium Player' system.
  5. Toka
    Toka Minimodder
    19 Nov 2006
    Article apperas to be missing any form of introduction / preamble.
    Not the best first page Ive ever read on BT.....
  6. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I never thought I'd live to see the words "Thermaltake" and "Great" in the same sentence... In honesty I'm surprised it's even up there with the Fenrir, let alone beating it :p
  7. SchizoFrog
    5 May 2009
    Just to add to my point... In the 'Premium Player' system you use 6GB of 1,600MHz DDR3 RAM from Corsair with the tall DHX heatsinks... Doesn't this mean that either the RAM or the CPU Cooler wouldn't fit together?
  8. SchizoFrog
    5 May 2009
    I'd still go for the Fenrir myself... It's just so much better looking than a big hunk of plasitc. Especially as there is only 8* difference between the FRIO with 2 fans on high and the Fenrir with 1 fan on low, while the actual temps are not anywhere near a CPU's overclocking limits.
  9. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    So it's a case of "The King is dead. Long live the King!" - Well done Thermaltake!
  10. bsoltan
    bsoltan What's a Dremel?
    14 Apr 2008
    The looks of it are a big factor. It is one ugly heatsink! (The Fenrir is no looker either). However if you're not planning to show off the innards of the PC this looks like quite a good choice, the price isn't too bad either considering it comes with fans.
    I have a question - In the reviews, there are temps listed for coolers that don't come with a fan. Are these temps taken when using a fan or just using the stock cooler? In particular this is about the Thermalright Ultra 120. Thanks.
  11. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    that is my thought exactly. IMHO if it is to good to be true, it probably isn't.
  12. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Those use a Sharkoon fan, AFAIK.
  13. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I mentioned it in an early thread but I'll reiterate: having to get into the case to adjust the fan speeds is a pain, I'm not sure I can agree with the overall conclusion here b-t.
    However, can the fans be replaced with standard PWM fans? How much of the excellent cooling is down to the fans and how much is down to the heatsink design?
    If it is the heatsink then one or two Akasa Apache PWM fans may be a runner here as long as you don't have tall RAM.
  14. SchizoFrog
    5 May 2009
    @ Fingers66... That is actually a good point you raise there.
    If the performance is not hurt too much then maybe replacing the fans with a single fan on the rear would give good performance along with freeing up space for RAM with good heatsinks. However, this would raise the overall cost even further and render the fans that are bundled useless.
  15. trig
    trig god's little mistake
    10 Aug 2006
    as usual, thermaltake does a half-a$$ job on what could have been a stellar product. but at least they fudged minor details and got the main piece pretty solid. nice job. i would buy, but i have ripjaws, so dont think it would fit.
  16. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Superficial review, it doesn't shows anything about the noise at which temps.
  17. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Please CPC can we see pics with it installed in case. I had to take my Titan Ferir out because it went right across two of my memory lanes on the ASUS rampage gene ii.
  18. FeRaL
    FeRaL What's a Dremel?
    27 Sep 2004
    Can it be mounted East to West?
  19. SchizoFrog
    5 May 2009
    Nice to see Bit-Tech are so quick to respond to questions...
  20. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    :p It's not like they have all day to spend on the forums. I've seen their busy days!
    There's meetings and testing and eating of food!
    It's madness, say I!
Tags: Add Tags
